you may find that it starts to ping up in the rev range as it will be leaning out.
only way to tell for sure though is to put it on the dyno. a dying fuel pump will generally have ok AFR's down low but the further up the rev range you get the leaner it gets because the pump will be maxing out and can't flow any more fuel. if the AFR stays the same all the way through the rev range, or gets richer up top then the pump is ok.
ok, does consult show afrs? or needs dyno?
will i hear pingning if it is pinging? i remember in my old vh u could hear loud pining when it did it
Edited by Clutch
The only way to read AFRs is with a wideband oxy sensor either on street or dyno.
But come to think of it, some of the laptop programs may be able to show your AFR if hooked up to a wideband as well.
Yeah you'll need the wideband sensor, I think Bosch ones are around $100? You'd still need software which usually needs to be calibrated to the sensor. Even the LM has a calibration, although pretty easy to work with.
One run on a dyno and they'll give you an accurate AFR, they can do a flow test while under load, and might even find other issues you didn't even know about. :P
My Stato pump died recently, I jumpered the relay and got under it, accidentally bumping the fuel tank, and it started again. Turns out they often have a crap connection in the tank. Good too, because I despise working on fuel tanks.
Edit: And with audible pinging, aint that pretty high on the 'ping' scale?
Edited by GTRPowa
when i had my car on the dyno last, was a while ago now. the dude richened up the afr's in the high rpms, on the first couple of runs, to make sure it wasnt struggling to supply fuel.
i guess that's how they test your pump?
shouldn't need much more than getting a few power runs done. you have stock ecu don't you? if so then they can't alter the AFR's to see what sort of headroom you have above what it is running.
you could also try bumping the boost up a bit from what you have it at, as it will be using a bit more fuel that way so if it is fine on the higher boost then it will be fine on what you are running.
agreed
i can up the boost but it goes way to R&R in midrange, but i guess that means the fuel pump is ok??? after mid range it speeds up a fair bit, would that mean that the higher rpm at higher boost is leaning out?
no, R&R doesn't stay the whole way through the rev range, it only stays like that for where the ecu is seeing too much airflow and throwing a tantrum. generally it will always come good in the upper rpm.
ok good, so it would seem my pump is ok then
sweet
was stressing that my pump would die halfway to philip island and id be farked.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
