Hi all,
Question:
Will a WRX (latest model 03/04) be able to run 22 pounds of boost on the stock turbo?
I had a quick run with a WRX (wagon) which went really hard, had a very quick chat with the driver and he mentioned he was running 22 pounds of boost...
Is that possible or is that new turbo?
Regards
Rob
https://www.sau.com.au/forums/topic/34620-running-22-pounds-in-0304-wrx/
If you see that guy again tell him to take his hand off it!
Stock WRX turbo is a Mitsubishi TD04 which is bloody tiny. Gives great response and spool-up time but as far as flow goes anything above about 17psi is just frying the air and begging for detonation. The turbo itself seems to be pretty bulletproof and won't fly to pieces to those shaft speeds but the inlet temps will definitely cause detonation and it won't be long before a ring land lets go.
Going above 16psi on a stock WRX turbo is pretty much a waste of time.
Maybe he had an Autometer Boost gauge and thought he was pushing 22psi of boost standard?
Cheers,
Ben
Haha,
It was neck and neck all the way until I had an extra 500 rpm in 3rd and got in front..
I have:
R33 gts-t ser 2
full 3" exhaust (turbo back) with high flow cat
10-11 psi boost
FMIC
oil air seperator
180 rwkw's (uni group eng.)
Regards
Rob
He could be running 22psi, whether of not it is benifitical is a different story.
I don't know where the boost cut is on the MY04, but i have seen my brothers (standard with full exhaust that's it) spike to 19psi.
Hmmmmm.....the boost cut should pull up stumps at about 17-18psi.
My car's stock except for a 3" turbo-back and the most I've ever seen is 1.1 bar (about 16psi). Then again different dump pipe designs can cause higher spikes. Does your brother's car have a dual dump on it. These can cause bigger spikes than open-mouthed dumps.
I guess old matey might have been running 22psi but he wouldn't be going any quicker than if he was running 16psi and he's stuffing his engine to boot.
Cheers,
Ben
It could have been a different turbo... I never said it was the stock turbo, just wanted to know how much boost the stock one could handle..
I would have guessed upgraded turbo, just didn't have time to ask.
Regards
Rob
Ps. A couple of times he managed to get all four wheels chirping on slight bends (showing off).. Don't know how hard that is but look impresive......
didn't the APS GC8 WRX run like 20+ psi in their car? the thing flew and it had a stock turbo...i wouldnt say its impossible at all.
i personally had my 98 wrx, allbeit with a 1994 td05 turbo, at 1.35bar with only front mount and exhaust doing 180kw at all four wheels. and its hit 1.4bar too.
I'm with you Franks. I'm not saying it's impossible. I test drove a MY99 that had a 2-stage boost controller. I flicked the switch and it went to 24psi. Went pretty good too but the massive amount of smoke that came out the back when on boost made me decide to keep looking. Rough idle was a pretty good sign that a ring land had been smashed.
I remember reading about the APS GC8-it was a white 98 or 99 wasn't it? From memory it was tuned to run about 17psi but spiked to 22 under certain conditions (uphill in higher gears). It had a Unichip piggyback engine management which are notoriously difficult to tune to hold consistent boost on a WRX. I think they eventually sorted it out to stop the spikes though.
I reckon the TD05 is a great BFYB mod. They'll comfortably push pretty big boost safely and it looks like you got some great results with it Franks. I was going to get one but a VF29 came up pretty bloody cheap so I went for that.
Cheers,
Ben
i think most people have the same problems with wrx's, i have my98, i installed a 2 stage boost controler running 10psi and 18 when racing, standard turbos were fine holding 18 but in the higher gears spiked to 22-23psi and on cold nights, but i know of a few poeple who race there wrx's and just change the fuel govenor helping to stop detonation by adding more fuel on boost, and they take the waste gate hose off and run full boost down the track, it might be stupid but you should see these stockers fly.
black smoke out the back, allbeit not pretty, is okay. its just your factory ecu overfueling because its gone off the map?
i'll give you a hint - don't buy a MY99 :) the theory is, the fuel pump from the 98 is the same as the 99 whilst the injectors went from 380cc to 440cc. Not surprisingly the 00 had the same 440cc injectors but had a different fuel pump....i would think slightly larger.
it is thus theorised, the fuel pump wasnt quite big enough for the larger injectors of the 99 and hence the more cases of ring lan failures at higher boost levels in MY99 GC8's...
cylinder #2 also sits on the end of the fuel rail hence another reason why this cylinder is prone to failure due to fuel starvation...
the aps car, i actually tend to think it was either a 97 or 98??? the non-forester dash is coming to mind for some strange reason so it may have been a 97??? my memory eludes me :D it was damn quick thats for sure though and it was running stock turbo ...
to your boost issues, maybe get an electronic boost controller? i know i had slight bit of overboost but thats the way i tuned my avcr ;)
as for the td05...yup! couldnt agree more. best $300 (second hand) i have spent on a car :)
It definitely wasn't overfuelling Franks. As soon as it came on boost there was a thick plume of blue smoke that hung in the air for a couple of minutes. It idled like a car that had a stuffed MAF sensor but revved cleanly. I rang Rigolis and Tony was certain it needed a rebuild. I was hoping it was a stuffed turbo seal or something but based on what I told Tony he was 95% certain it needed a rebuild. I was surprised that it ran OK with a stuffed piston.
Funniest thing was when the owner and his mate told me the smoke was because it needed a service. :bs!:
23 psi is big boost for a stock 03STi. These run a VF30 turbo which becomes inefficient on a 2l engine at about 20psi. This is just what I've heard but for some reason most big tuners like CRD, MRT etc don't push them past 19psi. The fuel system needs upgrading too-it's barely adequate.
Cheers,
Ben
Unlimited boost on the track hey? If u take the wasteate hose off, the turbo will just keep spinning until it blows itself to pieces!!
I was setting up my mates 99 wrx profec b spec 2 on saturday and we put high boost setting to 15psi. We ran upto 18psi but got alot of weird screaching noises coming from the turbo at that level so i dropped it down to 15.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
