Hey all,
When i go to leave for work my r33 wont start, it takes about 4 attempts before it starts and when it does start it runs very rough and coughs and splutter but after about 30 seconds it runs normally.
Can anyone help please?\
Cheers
https://www.sau.com.au/forums/topic/346855-rb25-dont-want-to-start/
not always
when my afm had dry joints the first time would intermittently break down mainly when cold until it got so bad it would just limp
had coil packs do the same thing break down when cold but get better when hot
primmed the fuel pump 5 times stilll struggles to start, the car goes like a rocket after its started once you get in running it comes good after about 10 seconds of running doesnt cough or limp , it just never wants to start
This is from the R32 Engine Manual for "difficult to start - engine cold":
1. Fuel enrichment from engine temperature sensor not working (sensor not working at cold)
- disconnect sensor - any difference?
- sensor resistance value?
- sensor voltage value?
2. Idle speed control (AAC) not working
- AAC valve closed?
- AAC valve plug disconnected?
3. Start time enrichment not working (check through CONSULT)
4. Cranking speed too low (sus battery, sus starter motor)
(presumably same or very similar for RB33)
hi, had a verry similar problem with my r33 gts, ended up being a leaking injector o-ring, pulled fuel rail on and primed fuel pump to check of any where leaking easy to check and easy to fix if thats your problem, 5 cent part big problem though.:thumbsup:
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
