Hi guys and gals,
need some help with my line :) Lately, when I've been driving, I get a sharp squeeling sound when I brake. I would need to brake it hard, for the squeeling sound to stop. Anybody know whats wrong, and how it can be fixed? Maybe, use some grease or something? :Paranoid:
Thanks, any feedbacks would be sweet! :P
https://www.sau.com.au/forums/topic/34686-squeeeelz-when-i-brake/
You may find that your pads have not worn evenly (or you may have sanded them back) and when you apply light pressure the full face of the pad isn't touching the rotor so it squeels (this is what I was told by a reputable brake mechanic in sydney). I get a similar noise on very few occassions, if I softly press the pedal I get a gentle squeeze but if I stand on it then it brakes like it should and without squeel.
You may also want to take ur wheel off and make sure the little shims are in place.
on a similar note......sorry for the hijack....my mates 96 rex makes a loud clunk noise from the front passengers side when breakin all the time. this was after he had them changed and machined. i think they left something out when putting it back together. any suggestions on this??
Knowing absolutely nothing at all about cars, could it be his castor rod bushes that have worn out?
My mechanic replaced mine because they were wearing out and asked me if i had noticed a thunk noise when stopping.
If it makes that clunk noise after you have just finished turning a series of corners it could be worn/wearing wheel bearings causing the caliper/rotor to move and then when you apply brake pressure it has to push everything back into place.
Where can you get some wheel bearings for a R33?
I get some small clunking when I'm turning and braking at slow speeds, I was thinking it was my caster bushes, it clunks abit when you are going straight and over a few bumps as well.
My brakes don't squeal when I'm going forward but they squeal like a b!tch when I'm going backwards.:Oops:
yeah he did mention that when he turned left the car feels strange like theres some reisitance. ill pass the info on. cheers guys.
RB74's are bendix ultimates rite?? mine dont squeel at all under normal breakin, only under really light breakin and of course reverse...hehe
RB74's are NOT Bendix and they are NOT DBA pads they are www.racebrakes.com.au pads. Bendix pads are designed for the daily driven Falcadores where as the RB74's are designed for the performance/track cars.
I put on a new set of Ultimates on mine a few weeks ago, and followed the 'bedding instructions' as per this site somewhere. I also have new wheel bearings.
They squeel under light braking, my old pads never squeeled.
The only difference I noticed between the new and old pads was that the ultimates only had metallic 'wings' on 2 of the 4 pads at the bottom, anyone know what these 'wings' are?
My stock pads & ultimates looked both the same. 2 of the 4 pads only had metal wings. As do the Maxi-stops I am currently running.
Did you remember to remove the shims from the origional pads & put them on the new?
Its easy to miss especially when the old pads are covered in lots of pad dust.
My ultimates never squeeked. The new el' cheapo Maxi-Stops ($26 an axle) don't feel anywhere near as nice, produce 1/8th the dust & squeel slightly after being pushed hard.
My pads didn't squeal until I had rear camber adjusters put in and the mechanic got the grease on the rear right brake disc. The front right brake now squeals. I think it got overheated having to cope with more braking as a result, probably just need right front machined again.
When I very very lightly touch the brakes the squeal is intermittent as the wheel turns it is only in one spot. Uneven disc? Perhaps carbonite build up? Can you see carbonite build up?
Would it be advisable to try putting some grease into the shims first or go straight for disc machining?
Would the grease on rear right disc wear off or will I need to use some brake cleaner or something to make sure it doesn't come back?
RB74's are very abrasive. 5 times as much I am told to Galver 1105's which stop real well, much better than ultimates.
Utimates are very very dirty and sqeal like a freight train, went deaf for a day due to the noise after 5 hours of driving, and to keep your wheels clean with Ultimates requires washing every day instead of once a week.
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
