As topic describes, I have been slowly putting this car together over a year and now that's it's together like most things, you want to get rid of them.
I bought the car with 90,000 k's completely stock standard and it now has the following
ENGINE:
SR20-DET 110,000Km rocker cover sprayed in metallic blue
Custom built 2871r .64 Hypergear turbo with welded up wastegate flap
Tial 38mm gate cast welded onto standard manifold (best manifold up to 250kw) with a custom made screamer pipe. The gate houses two Tial springs to reach a steady 18psi
HKS 256/264 10.5mm Step 1 camshafts. The staggered cam setup makes it so you can keep the VCT on the inlet cam gear. No aftermarket cam gears will ever dial in to get the response you get from the standard VCT unit
Custom Trust style bell mouth dump (went bellmouth as a split dumb is no longer needed due to external gate) down to an Xforce 3inch exhaust with high flow CAT
TRUST m-spec intercooler and TRUST hot pipe
FUEL
Nismo aftermarket fuel pump
Nismo 740cc Injectors
Sard FPR
SUSPENSION BREAKING & WHEELS
Lowered king springs
Slotted and cross drilled RDA front rotors with QFM pads all round
ENKEI RP01 17" Wheels with 80% tread all round
Whiteline front and rear adjustable swaybars
DRIFTSHOP adjustable castor rods
All of this is tuned by a PowerFC D-Jetro
There is more to list but this is just for interest sake at the moment.
Price is $22,000
Car is clean all round and has never been thrashed. I am 23 and still retain my original 17 year old licence for a reason.
I will get photos up soon when I can take some nice photos of my car.
Looking at buying a R32 GTR
https://www.sau.com.au/forums/topic/347068-s15-2001-australian-delivered/
Taking some nice photos tomorrow (Sunday 12th) but here is a photo of the engine bay and the gate setup. The car now also has smoked L.E.D taillights and smoked side indicators. It has an engine damper as well and complete stereo setup Pioneer all round.
  • 4 weeks later...
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
