I took the race car back to the workshop because the turbos were blown - noisey whistle as they spooled up.
Turbos showed evidence of oil starvation so I got an oil analysis done. results below.
This is on a 7 day old production race motor.
The main thing I understand is the smiley face.
Also interested to hear from anyone who does regular oil analysis as part of a preventative schedule
  • Replies 62
It does have a sad smiley. And I think 94x the acceptable level of bearing material might be a sign too.
No I have never used the redline oil before. Interesting that their analysis shows it is outside the expected range for 15w50 at 100oC. Whatever the expected range is at 100oC
I wonder why there is a shit load of lead in the oil?
Unless you are doing the sneaky sneaky and running Sunoco MaxNos lol
Is this the same block you have always been using? or is it a different block to the others you have killed?
Shit, that's not a bad price for the oil analysis, I would have thought it would be more. I wouldn't mind doing one with the new Dimple sump plug.
Also, where can I get my hands on your engine: RB2BPETT lol
lol at strange engine number. not sure what the P stands for either.
I assume copper and lead make up tri metal ACL bearings. that is why i was wondering who knows how to read/explain these things.
The block is a virgin in my use, although it was second hand and machined including 0.5mm overbore before this use.
not good duncan. I'll point Dan to this thread as he does all of my oil analysis and has had some in depth discussions with the oil test guys, but i think you have already in the nail on the head with the copper/lead being the different layers of the bearings.
The change in oil viscocity could be due to fuel dilution. 7.2% is quite high (i think mine is around 3.5-4%) and would have a significant impact on the viscocity of the oil.
p.s. we use WearCheck for our oil analysis, and i think they are a bit cheaper than that ($40 or less a pop if memory serves)
Edited by Strik3r
yeah I found that interesting too. 2x the acceptable level of fuel. petrol is not a good lubricant.
zeb, it is an entirely new bottom end, head was machined and re-used from an old motor, not the last one. unlikely (but never impossible) that it is related to a single bad part.
what about the clutch/flywheel or gearbox input shaft?
Something must be causing the crank to not move the way it should, not saying this engine is dead as I can understand bearing material wiping off in the 1st few hours of engine start.
But the fact that it keeps picking up bearings tells me that there is something not quite right.
indeed. new clutch and flywheel on this motor. same gearbox for years but new spigot bush, and they are all outside the sump anyway. FWIW also new harmonic balancer on this motor
Well I would say once the turbos go back on, give it a good run with new oil and test the oil again, fingers crossed it doesnt run a bearing in the mean time.
Oh btw did you find out what was causing the over heating on the last motor?
I'm thinking that the dead turbos maybe caused by the same thing? maybe the turbo oil and water lines are a bit blocked?
Oh and what i meant by the gearbox, is that the input shaft is not gun barrel straight it may be causing the back of the crank to move up and down.
Its a long shot, but may be possible
LOL I feel like I'm on myth Busters.
yeah but that would cause big spigot wear first right
overheating on the last motor was due to coolant loss (ie pressure test would have found the problem, but I never did one). eventually it did a head gasket from overheating which is fair enough.
BTW I don't want to give the impression I have had lots of spun bearing motors. I have had a few but reasons for each (oil system mistake, bearing clearance mistake and original factory motor). Also killed one with a dying fuel pump causing pinging. Killed 2 from overheating (both dead head gaskets - the one above and one because the radiator was too short for factory mounts).
The real question is - what does this analysis tell me other than the obvious (ie bearings are f**ked). No chance I am running the motor without tearing it down.
Easy one, dirty build mate.
See the iron content, thats your engine hone floating around in your oil. Id also go as far to say the cross block oil feed was partially blocked by bearing material from its previous life (engine that spun bearing) this also crosses with the evidence.
Id be keen to see the bearing wear especially the mains close to the centre of the block (3,4,5).
The fuel levels are also a concern, does whoever tune this thing want the rings to never bed in properly?
Edited by Supa Steve
Ah yeah fair enough, I was there at OP when the head gasket went...you should remember you forgot my seat! lol
I thought you had a few more die than that, that were un-explained, but if you know the causes than Ima shut up lol
thanks supa steve. BTW I am not sure of the previous life of this particular block, it may or may not have had a spun bearing before. I got it second hand and machined it.
oilcheck site suggests alumnium and silica are signs of dirt, mine are both outside normal but not flagged as critical like the bearing indicators. not arguing, just trying to learn....
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
