Hey guys. Had a tomei 1.2mm metal head gasket on my rb25neo and after a week the timing belt slipped and I had to remove the head to fix the valves. I've been told you can re-use them by a couple of people, I was just wondering what you guys think?
https://www.sau.com.au/forums/topic/347344-can-you-re-use-a-metal-headgasket/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
