Wrecking a R33 Series one,Black. Damaged on Driver Side. Most parts are good for sale but drivers door and driver quarter panel and front end.
RB25DET 117 000km on the clock. The engine has never been thrashed or mistreated. Always kept upto date with oil changes ect. $1100
Gear Box Stock standard 5 speed manual. $1100
Drift seats with rails, very good condition with rails to bolt straight upto a skyline. $500 with rails
Brakes nissan standard, Red painted with nissan label in silver. $400
Rotors all 4 $200
Rear Differential $300
rear taillights $300
Boot with look and swivel series one spoiler, $120
Exhaust very good condition 3 and a half inch, not to loud. From Turbo to tip $300
Most interior is in good condition if after anything, ask and a good price can be arranged.
I also have a 400r Bar which i never got to install, its for a series one. It is currently sanded back with no paint, indicators come with it $130
If you have any questions i am happy to answer them, message or call any questions to 0435294855
The parts are in Adelaide at Fulham Gardens
https://www.sau.com.au/forums/topic/347502-r33-series-wrecking-black/
post-64474-0-54222800-1293783741_thumb.jpgpost-64474-0-98616000-1293783711_thumb.jpgpost-64474-0-07510200-1293783602_thumb.jpgpost-64474-0-19289800-1293783572_thumb.jpgpost-64474-0-19289800-1293783572_thumb.jpgsome pictures of the stuff
please note the seats are now 400 as the drivers rail is damaged could be repaired with welding but thats buyers decision.
The 400r bar has rash along bottom not visible when installed on car.post-64474-0-19289800-1293783572_thumb.jpg
Hi - chasing a passenger side Electric Window motor. happy to pay post tp Brisbane.
Denis 0403829350
hey dennis i want to sell the passanger door as a whole at the moment
Hey mate do you have stock wheels, or are willing to part with your wheels cheaply? I'm in Adelaide can pick up, pm me if you have anything.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
