hi guys,
im stuck & need advice...i am not happy with my r32gtr shell so im pulling all of my running gear out of it & tossing the shell - more than likely will keep the engine as it owes me 25k & probably sell the interior, diff etc.
i am on the search & here are my 2 options (both are at similar price point):
1. red 94 r32gtr: forged bottom end, -5's, nismo wheels
OR
2. white 94 r32gtr vspec2: stock bottom end, -7's, volk wheels
which would be a better buy? i can see that i'd make more money from selling the forged engine etc on the red gtr, however, the vspec2 is more of an icon & better for resale i guess...what are your thoughts? this is doing my head in ARRRRGH :)
i can also say that the red gtr is cleaner, but the white gtr just needs a bit of tlc to have it look as nice
regards
marko
i put together a quick analysis & after selling parts i'd naturally get a lot more back with the red gtr...the difference is over 5k
from this, it will cost me an additional 5k to have a vspec2 which doesn't sound too bad really...
VS2 and how good are you at haggling? VINs noted and Checked for rust?
BTW, how do you know that the 2 owners aren't on SAU (assuming these are already in Oz)? If they are, they'll vote for their own car eh? :P
hi all,
i had the white vspec2 inspected a few days ago, the chassis rails & sills are badly pushed in...can these be repaired or should i stay clear?
also has rust under the n1 boot lid (on the actual boot lid itself, rust straight thru), under the passenger mirror in the door sill itself, rear 1/4 guard arch & the bonnet paint is lifting off the alloy bonnet near the n1 front lip, wtf!
i also looked at the red gtr (non vspec) & the condition is incredible - very nice indeed :) reminds me of my aust delivered gtr which i had a few yrs back
Yes chassis rails can be repaired depending on how badly damaged they are. The can also be replaced but both repairing and replacing is a big job. I think your better off going with the normal GTR for the same price cause if you get the V-spec its going to cost a fair bit of coin to get it all fixed up to a standard that your happy with the car
  • 3 weeks later...
  • 4 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
