Not exactly sure if this is the right place so feel free to move.
Car is a non turbo r34 GT four sedan.
Bought a Fujitsubo Legalis R from JustJap and when I tried to fit it, the front half of the cat-back (the one with the mid muffler on it) is roughly 11 inches shorter than the stock one.
I've pm'd a couple of members and no one else has had any problems but Tokyo Taxi has said I might have an exhaust to suit a coupe or have the shorter r32/33 cat converter installed.
I don't think Fujitsubo make a cat-back with dual outlets for the r34 coupes and I don't believe the stock cat-back has been extended to fit a shorter cat, so I'm stumped as to why this exhaust won't fit.
Currently waiting on JustJap to get back to me to confirm if I was sent the right exhaust. This is also the first mod done to the exhaust as far as I know, so everything should still be stock.
If anyone could shed some light, it would be greatly appreciated.
Also, I need the JASMA certificate translated as there is a "2" in a dubious spot. So if anyone can read printed kanji, I can post up the certificate.
thanks
https://www.sau.com.au/forums/topic/347597-r34-gt-four-sedan-exhaust/
Well how's that for a rare unit, don't tell me it's a manual too? :)
I had similar trouble trying to work out how to chop an R33 catback system for my R34 GTT sedan. It's got different engine and transmission setup of course, but perhaps there's something useful in these two threads:
Good luck.
Edited by V28VX37
Good luck.
sorry for the late reply, forum notifications not working. at least i didn't receive an email.
actually, it is manual :P
I think I might have solved the issue but I'll have a read of those two threads when I get home. thanks for the info, buddy. really appreciate it
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
