It doesn't have to be on the 20th/21st Ska
Both me and MJ are cool for any Sunday, I just want to make it worth Spectrix's time to do this.
Lets just wait and see who else bites first before we commit to times and dates ;)
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715324
  • Replies 168
Hey cam.
Your cars still off the road hey.
I hadn't forgotten about you dude. By the time you have the GTR running I might have found some Brembo stencils for your calipers.  ;)
Hey mate,
Yeah still off the road, although things might be looking up as I am picking up the turbos this arvo & have got all new hoses from my brother who works at Westpoint Nissan & are picking those up this arvo too.... so shouldn't be too long away now...
Cam
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715449
Hey mate,
Cam
Excellent news cam. You up for a trip down the coast? ;)
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715457
Gets towed there tommorrow, and they said it was all booked out this week, but may be able to squeeze it in, you know how good they are, so I would not expect it this week, hopefully fingers crossed, next week, oh also found a cheap tow truck dude who comes highly reckomended, so once he takes it there see how good he is and post his number so that all can use a good cheap tow truck.
https://www.sau.com.au/forums/topic/34830-hello-all/page/5/#findComment-715585
    • I'll just leave this with, holy shit, those cars at work are awesome, and this will look wicked!
    • Could you modify this duct so instead it pushes the extra air through the radiator too and not down and out? For temps, I know it's not the greatest idea, but as a bit of a last resort, you could use a very intermittent misting spray onto the front of the coolers/rad. You don't want to be soaking them such that water is dripping off, but a small most on/off so that the water evaporates. That point of it constantly evaporating, rather than being soaked in water, will pull a LOT of heat out of the cooler. I'm literally thinking just the little mist sprayers for a garden from Bunnings. Being in a low humidity climate it will help even more! The other trick if you want to be ghetto is some shade cloth hung in the opening, and keep it wet. Pretty much now it's acting like an evap cooler on a house, but cooling the air you need to use to cool the radiator...   On a topic to think about too though, when air enters through the bumper, is it all nicely ducted from the edges of that opening back at a nice angle, or is it like most cars, and the edge of the opening just stops, and suddenly it's wayyy wider behind that? If it does the later, get it shrouded out at nice angles. When that opening changes too rapidly, it can actually cause a high pressure zone between the front bar and radiator, and limit air flow into that area, which means less air for cooling, as it effectively stalls the air, AND adds to drag...
    • Do you have any before and after photos? That's $200 just for the hydro blasting?
    • It doesn't look like there's a lot of options out there these days, and what's out there is performance oriented aftermarket stuff (with the GTR markup) I wonder if there are other cars with similar springs, after all its just a matter of length, diameter and stiffness. Alternatively, I did see coil spacers. Probably not the best option, but could be serviceable too.
