Update.
Diff sold
Gearbox sold
Tailshaft sold
Engine fan sold
Radiator mounts sold
Many parts deposits taken
Car is now at new location in workshop so much easier and quicker for me to strip and get parts shipped off. This also means all parts including rolling bits can be sold.
No name rose joint caster rods $150
Shortened upper control arms (have been lengthened they were too short) $150
Steering rack $100
Hicas lock bar $60
Alloy sub frame pineapples $60
Engine mounts $30
Front bar $120
HSD coil overs fully adjustable 16 step shock (might be type S) $550 all four
All aircon, glass, doors, handling parts, subframe, lights, and many bits still available so please feel free to make offers on anything.
Cheers,
Daniel
Radiator Sold
Lots of stuff here,
Lightly faded back seat good condition $50
Malpassi Adjustable EFI Fuel Pressure Regulator $90
Bonnet $120
Boot $90
Doors $100 each
Door trims $55 each (drivers sold)
Steering rack $100
Power steering pump $60
Larger alternator and cut bracket to make it fit $100
Front bar with reo $120
Disc to disc Sub frame (minus diff, hicas, coilovers) $250
Need to get parts moving or it will be sent to the wreckers.
C pillars sold sorry. Make an offer on any or all aircon parts, thanks
Hey mate,
Would you still have the trim and boot for the gearstick, if you do are you willing to ship? Keen as FK as ive been chasing one of these for over 9 months now
Cheers,
Brenton
PM's replied thanks people. Starting to move quicker now, anyone want a shell with many spares? Thinking $2000, has all doors, dash, carpet, glass, electrics, lights, boot bonnet, complet brakes R33 GTR fronts, hydro handbrake, wipers, wheels with good tread, half shafts and most of suspension, subframe, battery (boot mounted), some trims, probably more that I haven't remembered...
Yes I have stereo brakets, $25
I have got the complete center consol but it's been in a shed since I got the car so needs a good clean $35
HSD coil overs Sold
Got front and back strut braces $90 front, $70 rear.
And surprisingly I still have very good condition full amber indicaters, the ones that make your donk sexc!
if he does not get the radio brackets i will get them as i need them and the centre consol if you have that i will get that to
just send me a picture of the items 1st just to make sure there correct
can be via MMS or what ever
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
