:headspin: Alright I finally am getting my front mount fitted 2day. Plus highflow cat and front pipe/dump pipe fitted.
So the question is anyone want to give me a rough idea on how much power i should be making at the wheels, with above mods plus pod filter.
I dont really want to spend money getting a dyno run done, saving for that when the wolf or power fc go in ( next month hopefully).
Cheers
https://www.sau.com.au/forums/topic/34850-estimate-the-power/
230-250rwhp sounds sweet for the little money i have spent.
so next week (that would be march 3rd) on wed might take it down the plex and see what she can run. Guessing a mid to low 13.
My guess is a mid to low 14. It's just a guess but, I've not seen many fmic equiped R33's make it past flat 14's on the stock turbo and ecu.
good luck.
Hopefully tomorrow nite I become 1 of these few with the stock ecu/turbo to break into the 13's.
I've got the TS to do -atleast- a 13.9sec and thats with 1st gear being useless so if I can get rid of axle tramp im hoping for a TS of up around 102mph (which makes a 13.3sec possible).
Ok my target is the 350rwhp mark.
Next mod is engine mangement would i expect to see around the 300rwhp mark with some good tuning.
that's probably a bit over-optomistic.
gus and dan have both recorded good results with pfc - and on the basis of their outputs, a reliable 280ish is probably reachable.
paul and steve managed to scrape a bit more out his factory turbo and wolf setup, to take it past 300, but the turbs didnt last long..
i have 9psi (spike valve), stock cooler, stock turbz, pod, no hi-flow cat, dump/front pipe and a cat back and i did a 14.07 @ 98.6mph with a 2.11 60' i doubt a mid to low 13 is possible because kym is running ~260hp @wheels and i was beating him all that night and his best ever is a 13.98... :D good luck with the run tho... :D
ps. with no afr control...i would say keep the boost about 11psi and get about 240hp so you dont run too rich... :)
adding to that Fane, I was running 9psi, with NO AFC, and a 2.2' 60' time....I had around 230rwhp around that time :D
*cough* oh, it was 13.96 too - let's not forget the 0.02! :D
now that teh AFC is in, I gots more power and less traction. P.S. Falken's are sh*t tyres for dragging!
car already runs rich with only cat back exhaust and pod filter. Since exhaust was fitted some time back went from 450km per tank to 350km per tank. hope it doesn't get much worse than that.
Although having a lead foot doesn't help the fuel situation.
Hope to see some of you guys at the plex when i take it down.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
