Hi guys,
Purchased a R33 Gtst last week, mods: fmic, 3" exhaust, power fc, z32 afm, bov, fpr. It's always been running fairly rich on boost which im not too worried about as when Unigroup Engineering re open i'm going to take it in for a tune, but what ive noticed now is that if you have the air con on the car will spew out black smoke constantly even on idle, as soon as you turn the air con off the black smoke goes away and it only returns on acceleration when the car starts making boost.
On the FPR gauge under the bonnet the car runs around 40psi with aircon off at idle and 45psi with aircon on, are these normal values?
Anyone got any ideas what could be causing it to run so rich all the time once air con is put on?
Thanks
https://www.sau.com.au/forums/topic/348880-r33-gtst-running-rich-on-idle/
thanks for the reply, im trying to remove the aac now undid the 2 plugs going into it and took out the 2 bolts but it seems to be staying firm and not budging is there a special trick to get it out?
The trick is that there are 3 bolts holding it on >_<
BOV
If it is atmo it will run rich at idle because it will be partially open and not returning through the normal return pipe back into the system
Might have been tuned without the AC on so its fine until you turn the AC on
try at idle just holding your hand over the BOV outlet so no air can escape and see if that helps
Thats just assuming it is an atmo bov
Edited by 89CAL
Thanks for the reply, I'm fairly sure my BOV is plumb back but I took a picture to be sure as i'm still learning
Also I should mention the car is terrible on fuel only getting around 250 - 300 kms per tank of bp ultimate
yeah that is plumback so the bov should be fine
but they may not have tuned the idle with the AC on properly, but because I dont know who tuned it or anything like that, I'm not gonna slag on the tunning to much
try cleaning the AAC, and get some contact cleaner and lightly spray the sensor inside the AFM. Thats pretty poor fuel economy (unless your thrashing it everywhere)
I was fairly easily getting around 400km to a tank with my tune and the stock turbo, only mod i didnt have that u do is the FPR. That was giving it a bit every now and then
if all else fails take it back to your tuner and say your unhappy with the fuel economy and how rich it is at idle and see if they will have a look at it
nah I dont thrash it ive been babying it as it blows too much black smoke when i give it a hit, ive cleaned the aac, ill give cleaning the afm a go tomorrow. other than that i think ill have to take it to a tuner to look at..
Edited by DMS87
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
