I have a few games that I'd like to sell / swap
All in top condition (some as new condition as they've only been played a few times)
1. DragonBall Z Budokai
2. NBA Jam (2004)
3. Smashcourt Tennis
4. War of the Monsters
I think that's it for now.
Games I'm after:
Soul Calibur 2
Virtual Tennis 2
DBZ Budokai 2
can post. preference to pickup from Macquarie or Strathfield
https://www.sau.com.au/forums/topic/34895-ps2-games-for-sale-or-swap/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
