For future reference
Some of the info in this thread is not correct (points finger at Terry, nicely)
I run 19x9.5 +12 GTC's Face 2 (BAKES old R34 GTR wheels)
He use to run a 3-5mm spacer to clear the Brembo's
+12 Face 2 are "B" disk. They miss my R34 GTT calipers by 1mm
+11 Face 2 are "A" disk which are for brembo's. Only 1mm different in offset but 5-6mm difference in caliper clearance
You can confirm this reading the Rays wheel charts
The difference in extra calpier clearance on the A disk +11 is done by running a smaller outer rim width (less dish) than the B disk +12.
Sorry Darrin and others if I got A & B mixed up! Dear oh dear, I hope no-one bought GTCs that have spokes crashing into the GTR calipers!!!!
Volk GT-C rims looks good on a BNR34, i've had mine on the car for about 6 years now. still looks good but becareful as the dish scratches really easily.
F**ken HOT !
what size and offset you got there bud ?
Hey all,
im in the same situation as a few of you on here, except i have an r33 gts-t and im in currently trying to figure out what all this offset 'jazz' means, as im currently in the market for some 19in gt-c face 2 rims..
Do the off-sets and other specs differ from a gts-t to a gtr when in comes to clearances and fitments???
What to you recommend for someone in my situation??? please help!!
Also Dumpe, are u selling those te37s once you've got your new treads??
cheers, henson!cheers, henson!
  • 10 months later...
    • And one last super random thought, I remember when SAUNSW had a dinner with Alan Heaphy, and another with Fred Gibson there was talk of the R32 GTR cast alloy uprights failing in racing, and one of the things Fred did when they had to add weight to the vehicle was taken the failing alloy uprights, and have them made of steel. Does anyone remember back to 1990/1991/1992 and WHAT was failing in the front hubs/uprights?
    • If you truly want to know how the original failed though, was it a factory defect possibly etc, send it off for investigation. Would probably cost a shit tonne.   The ones that you need to win lotto for, unless you have a good reason for that part to be bolt on, I'd probably roll with getting a few small stitch welds carefully put in place as an extra safety factor once everything is all torqued up tight
    • Are you sure? Because I wouldn't necessarily be. Do we even know the material they've made the new uprights from?   Looking at the fractures in the earlier pics, it does to me look like both a twisting, and levering upward action doing the damage, so you're hoping for both compression, and tension. Depending on the bolts, they can stretch (even high grade bolts will) and now you're hoping for the threads themself not to stretch, as if they do, bye bye mating surfaces holding together, hello bolts now going into shear.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
