R33 GTS-T Series 2 Skyline - Gunmetal Grey
Please PM me via the forums, send me an email to [email protected] or call me on 0407 229 095 (after 4pm on weekdays) if interested.
Please note: No joy riders! We've heard too many horror stories.
Also no paypal payments.
Excellent performance and handling, owned by female owner since import in Oct 2002. Rego renewed till Oct 2011.
2.5L to 3L conversion engine professionally built by Pro Concept Racing in Seven Hills late 2006/early 2007, producing 324RWKW on very conservative boost and tune. Also regularly serviced with log books by Pro Concept. All receipts still held and available for inspection. 141,000kms clocked with 45,000km done since the rebuild with only general day to day driving, no thrashing.
Too many modifications to mention, snapshot below, please contact for any inquiries.
ENGINE:
Garrett GT3076 Turbo Charger
Nismo Oil Cooler
Greddy air inlet manifold/plenum
HKS BOV
Front mount intercooler
CP Pistons and rings
Tomei head gasket
Tomei Valve Springs
ARP Studs
Nismo engine mounts
Custom piping
Nismo 550cc Fuel injectors.
Splitfire Coilpacks
Apexi Power FC programmable ECU with hand controller
DRIVETRAIN:
Nismo twin carbon fibre plate clutch
Cusco lightened flywheel
Upgraded slotted brake rotors front and rear
Custom Turbo back exhaust from HiTech Mufflers to meet EPA requirements
HANDLING:
Tein adjustable coilover suspension
Front and rear strut braces
WHEELS:
Volk TE37 Bronze – 17” x 8” front, and 17” x 9” rear
INTERIOR:
Defi 3 x gauge cluster – Oil Temp, Water Temp, Oil Pressure
Greddy boost controller
Turbo Timer
SECURITY:
Currently has QuikTrak installed and can be transferred to the new owner
PICS:
ASKING PRICE:
22k ono
https://www.sau.com.au/forums/topic/349083-fs-1997-r33-gts-t-324rwkw/
Oh weird! Didn't even get notified that there was a response on here!!
Thanks dude :) I think its finally time to let go :(
I'm willing to drop on price for reasonable offers.. the car really is a rocket ship... beautiful to drive... its just wasted on me these days... using it as a daily driver doesn't make sense anymore :)
PM or call if interested :)
Mona
  • 4 weeks later...
pity your not in perth. Id do swapsies with my GSXR 750 for that thing...
good luck with the sale mate. Nice dirty 30 sleeper :)
Nawww... that would have been awesome!! And thanks :)
swap for a 270rwkw R33 GTR with some cash my way??
and nah thanks.. really a moving away from the whole scene :P
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
