On the body side of things, leave it stock with a tuff set of rims Volk GT-C's spring to mind. The R34 is already a mean looking car, maybe add a vented bonnet for abit more of a tougher stance but the money you save on body parts you could put into your engine and driveline, a few k in fibreglass could be spent on adjustable suspension, brakes etc.
my two coin
Cam
P.S
be thankfull you own one, many of us dream of owning this car lol you don't need to go all out you have one of the best cars ever made already.
Red R Racing charges around $2500 for a 26 rebuild with machine labour around the $2000-$2500 mark including cylinder head (mine was a little dearer as i had a hybrid custom engine built). They have around 25 engines currently in service and with an excellent reliability record. They are responsible for engine in the 1350hp Nitto R34 (dyno comp proven 1070hp at all four), their own 9 second street GTR and many others on here. Their quality of workmanship and attention to finer details is second to none. Ive personally seen engine bearings come out of their race engines on freshen up that still appear brand new with very little moly coating removed so the bearing clearances and oil grade selection for the application is nothing short of exact. They can arrange freight and even manufacture their own export standard sealed delivery crates. Quite a few workshops now outsource their engine work to these guys as they have proven to be one of the best options in this country. Paul is also a very handy fabricator and has recently started manufacturing their own lazer cut and tig welded 9 litre race sumps and lobster back exhaust systems.
I had my Nitto 30/26 built there and hasn't missed a beat having built a few engines myself over the years i know what it takes to get things right.
my two coin
Cam
P.S
Cool, thanks!
But insurance is paying for the body parts, the splitter and lower lip are being replaced along with intercooler, so there is some scope there to do some work.
Thanks, that is the second vote for Red R, will give them a call!
+1 for anthony scali @ xpseed. What kinda of prices are they charging you to do it interstate, and how much is frieght?
Have had a chat to X-speed already, they are my current mechanics.
They are saying $6,000 in labour just to build the engine, hence why I am looking to Lewis Engines or someone like that.
But the costs from X-speed was pretty much as follows;
$1,100 pistons
$1,000 rods
$700 head gasket
$2,000 head overhaul only, no porting
$600 bearings
$800 gasket kit
$500 hose kit
$1,600 HKS oil pump
$6,000 labour
$2,500 Machining
Lewis Engines;
$12,569 plus $399 freight;
Block bored,honed,decked, cracktested, oil restrictors, Crank collar, cracktest,grind, blueprint clearances, microppolish
Acl comp bearings, JE forged pistons total seal rings, Spool h beam rods with arp 2000 bolts, Arp main and head studs
Steel 4 layer head gasket, Tomei oil pump, Genuine Nissan gaskets, Tomeii 264 cams, Springs step 2, Full recon head,refaced,guides,multi angle valve job,seals ,tappet adjustment, 300cfm port job –maximum, Hi octane hi vol race sump extension and baffles also mods to oil drainbacks in sump
Assembled complete sump to covers
You got any contact details for them??
Can't find anything useful on the web.
call paul direct on 0448822360
they built the cylinder head on the R34 that was recently on the cover of HPI, i believe this is an xspeed car also. Bakes R34 is another Red R special.
http://img16.imageshack.us/i/66330418.jpg/
http://img7.imageshack.us/i/76470055.jpg/
there is adiffrence between screwing an engine together and the dude who does the machining
the person who does teh machining is the person to be praised as they make the assembler the person who looks good
simple fact
the person who tightens all the bolts jobs is to measure the shit out of it and check the machinists work.. a good one of these finds the issues before you even put it together
simple fact
In most instances the machinist works under instruction from engine builder. Machinist generally has no idea of application and therefore has no idea where clearances need to be for every engine. Different brands depending on application can vary quite a few thou just in rb piston selection let alone bearing clearances which even the oil grade being used can influence. The completed package is a combination of knowledge and skill of both engine builder and accuracy of machining and measurement.
i definately disagree
find a decent machinist and stick with them
eg roll up with parts
state if you want 400 or 800 hp or more
pay money pick parts up and screw it together checkin the his stated tolerances
if you telling the machinist what tollerences you need for your engine and what oil........ typically the engine builder has ben told by the machinsit before, has got a few engines running putting around running numbers at those tollerences and then the asembler tells eveyone what tolerances he likes on his engine and it was his idea
i guess it comes down to what snake oil you need to buy in the end
I think the key here gents is make sure the machinist and the engine builder are the same guy. I have always tried to do that in the past :thumbsup:
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
