After putting in my new koyo oem radiator (looks identical to the stock one), it's time for a new cap. I currently have a SPAC/PIAA "53" 0.9 cap which looks to have reached it's useful end. So I need to get another one.
However what are the benefits to using a Nismo 1.3 cap? Will my car cool better as the descriptions I've read say it will?
And another question, is 0.9 the correct pressure cap I'm supposed to have? My car is a pretty much stock R33 GTST. All I've done is ground the boost, and installed a FMIC. The reason I ask this, is on the nengun.com website, their description of the Nismo 1.3 cap, mentions that stock is actually 1.2 !!??
"The Nismo radiator cap is a heavy duty radiator cap, which operates at 18.2 lbs (1.3 kg/cm) compared to 12.6 lbs (0.9 kg/cm) non-turbo and 16.8 lbs. (1.2 kg/cm) turbo Nissan OE(Original Equipment) stock caps."
http://www.nengun.com/nismo/radiator-cap
So does that mean me having a 0.9 cap all this time was wrong, when I should have been using a 1.2?
Confused :wacko:
Edited by KrazyKong
https://www.sau.com.au/forums/topic/349130-radiator-caps-spac-skunk2-vs-nismo/
if it is supposed to have a 1.2 cap and you had a 0.9 cap then things may not have been working as effeciently as they could've and going to a 1.2 cap would be a good idea. on the other hand if it is only supposed to have a 0.9 cap then i wouldn't recommend going to a higher pressure cap for the following reasons: if you need it to sort out an overheating issue then you should try to find the actual cause of the overheating issue rather than bypassing the problem a bit. also if you raise the pressure of the cap then you are putting more stess on the rest of the system and may find that if there is a weak spot in the cooling system it will vent pressure there instead of the cap, which can result in blown hoses, etc.
but first you need to have the standard pressure of the cap confirmed, which i'm not able to do.
I rang Nissan today and they said the standard cap in their system for all R33's is a 0.9. So I guess that settles things. It appears Nengun.com have incorrect info on their listing in regards to non turbos using a 0.9 and turbos using a 1.2.
Off to find a new SPAC cap then as it seemed well made. I'd love to get a Skunk2 cap as it's all nice and matte black, but it only comes in 1.3 I think.
If it has a .9 in it replace it with a .9
There's no harm in asking. Not when my heater core went... then my radiator going less then a few hundred kms later. And my cap isn't a stock one either, it's some aftermarket thing with Japanese writing on it. Thus I'm not going to assume anything, and instead felt it better to ask.
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
