Pretty much as the topic states, im having a few dramas with my R33 GTST s2.
Atm it coughs and splutters and has zero power for a while when its cold, itll hunt and just plain piss me off and play games but once it warms up its generally fine.
In the last few days its been getting worse and worse and is now starting to not come good and do the same when warm.
Looking at the consult data everything is fine and working normal except the A/F alpha reading sits on 100% all the time and the A/F alpha self learn is at about 97%. also the exhaust gas temp sensor is 5V all the time. Im not sure what the normal ranges are so any help would be greatly appreciated.
Car has a stock ECU (speed limiter removed) stock turbo, FMIC, stock BOV, running stock boost atm because if i raise it even a little it coughs really badly.
Also has RB30 botton end with a RB25 head, coils are brand new splitfires, new Airflow meter, cleaned IAC and throttle body. Im also just about to get new plugs and see if that helps.
If someone could post up a consult log or give me some ideas of normal readings that would be great, also any other ideas would be more than welcome.
Ill post up a consult log when i get a chance.
Cheers shaun
https://www.sau.com.au/forums/topic/349390-consult-data/
It also has a new O2 sensor (replaced 500km ago) and got new plugs and a heap of vacuum line today so i can replace all the vacuum lines tommorrow.
Drove it this arvo and had no problems at all, started fine warmed up for about 5 min while i was getting the Consult software to connect then drove no worries.
The temp is also sitting at 102 degrees? but it was a hot one today (around 35 deg). It has an magna thermo bolted to the radiator which runs off the ignition rather than the crappy viscous crank driven one.
I really hate intermittant faults, any one have any ideas?
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5613707
yeah for the moment, getting a new ECU when the shops open back up in a few weeks. I was going to get a link but now im thinking Power FC D Jetro. I think the stock AFM is maxing out when i wind the boost up which is why it coughs on 10psi but that doesn't explain the stuttering and coughing when its cold. It was running fine for 2+ years with the stock ECU its only been the last few months i've had problems. Im really just after a Consult Data log to compare to my readings so i can see if there is any obvious fault.
cheers shaun
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5613915
ok a few things,
1: what temp sensor is being used? the rb25 one?
2: how has the speed limiter been removed? has the speed wire been cut or is it a remapped ecu?
if the car is running at 102 degrees then it is way too hot. either the thermostat is shagged, or the water pump, or the radiator..... or a combination of the 3. the stock vicous clutch fan are actually a very good system when (when in good working order) and are not worth replacing unless the clutch has stuffed up.
running the 3.0L engine off the 25 mapping is more than likely causing issues. are you still running the stock 25 injectors? if not then that will be part of the problem.
A/F reading will have very little to do with the problem because you can run the car perfectly fine without an o2 sensor. however the EGT reading interests me since the rb25's never had an EGT sensor as far as i am aware.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5614247
Its using the 25 temp sensor and I replaced the fan because it was shagged, im fairly sure that the ecu was remapped at some stage but i have no idea what was done.
Ill replace the thermistat tommorrow and flush it all out again and see if that drops the temp at all, the radiator was only replaced a couple of years ago so it should be fine but ill clean it out and check it over anyway and the radiator cap is also new.
According to the manual the R33's have a cat temp sensor/exhaust temp sensor to bring up a warning when the cat dies. Not sure what its meant to sit at though or if its just an on/off kind of thing.
Its running the stock 25 injectors, which are on my list to replace when i do the ECU as they were nearly maxed out when it was tuned with my old e-manage for 10PSI.
Also just to annoy me some more its been all good for the last two days so i cant get a log of when its running crap.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5616105
EGT always reads 4.98v on nearly all cars ive seen, im not even sure they did this EGT sensor right in the consult unit (i.e. it might not even be a voltage reading by a mis-interpreted switch status, e.g. EGT is 'not hot' or 'too hot'). the 100% and 97% isnt anything to worry about.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5616210
cheers, thats one less thing to look at.
It started coughing and playing up again tonight but the air temp here atm is a lot cooler than it was today so im thinking maybe a dry joint in my AFM. Ill pull that off and check it tomorrow as well.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5616318
Any one know how to upload consult data? i cant seem to get it to work.
I think i know why its coughing so much when its cold. It seems that the airflow meter maxes out (5V) on WOT when its not completely warmed up or if the outside air temp is a bit cooler.
When its warm it peaks at around 4.7V. Im guessing when the AFM maxes out the ECU cuts ignition or goes into limp mode, which would also explain why it does it when i raise the boost using my Greddy Profec as it spools up alot quicker (even only a small increase in boost causes it to cough badly).
I might try lowering the gain on the boost controller so it comes on a bit slower and set it for 9PSI and see if it makes any difference.
Looks as though ultimately im going to have to wait until i change the ECU before i can wind up the boost ( I only want to set it to 12PSI)
Cheers shaun
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5616962
car bad start.zip
Thats a log from when its cold and running sh*tty, hopefully it worked, it should open with the OBD scan tech software. I have version 1.29 if that makes any difference.
Anything stand out to anyone cos im stumped..
Cheers shaun
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5620456
should have used ecutalk for the logs, scantech logs dont include time and hard to graph the on/off sensors
and need to be able to tell us when in the log its 'coughing' e.g. here you have 3 goes at the accelerator (it stays >750rpm all the time) and then a pause, and in this time the rpm drops around 600s, and then another couple of bigger stabs (the second goes pretty high on the MAF for no load...its a RB25DET maf right?). so is this coughing in between those stabs where its doing it for a while?
anyway, if you graph it, notice how your AAC is close to 100 - this means it has no room to let more air in to keep idle higher. so your idle screw might be set too low, or you might have dirty AAC. try the base idle mode, its in free conzult if not in scantech, make sure engine warmed up fully, and see how the engine idles once u start the base idle/timing mode - if at a low RPM (or immediately stalls) then idle screw likely set too low.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5620606
Thanks man ill have a go at that tommorrow arvo, Ill also try to get a better log of it using ecutalk when its playing up. I still havent had a chance to do the plugs or vacuum lines yet either (been raining up this way a bit). Ill clear the junk out the garage tommorrow and stop procrastinating.
Its running the stock R33 AFM (pink label). It mostly hunts on idle and chugs black smoke for a few minutes but once it warms up a bit it settles down. It also intermittant some days i have no dramas at all.
The coughing happens randomly when im driving along and give it a bit of stick. It'll either cough at around 4 grand (cough as in die completely for a half second), sputter and feel really sluggish or pull through to 7 grand (still has a bit of a flat spot between 4-5grand but pulls through it).
Coils are brand new, plugs <3000Km old as well but im changing them again anyway
Cheers for the help
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5620661
Righto, think ive managed to fix it, I changed my plugs today with bcrp6's gapped to 7.5mm, cleaned out my AFM (wasnt dirty but blasted it with contact cleaner anyway). Also replaced all my vacuum lines and replaced the rubber joiner between the throttle body and intake pipe (was a bit worn but no split or cracked).
I let it cool right down then took it for a drive, i think ive somehow deleted the consult software from my laptop and cant seem to find the disk so i used scantech again.
First one is straight up after i let it idle for about 5 min, running wastegate boost (gets up to 10PSI???)
car cold.zip
Second run after it was warm i set it to low boost on my controller ( starts at 8PSI and builds to 10.3PSI at about 3500rpm and holds till 7000)
boost.zip
Third one is when i set it to High boost (11.7PSI comes on hard). It maxed out the AFM and coughed so i set it back to low boost. You can see the AFM hit 5V just before the revs drop off about 150 frames in when it gets to 5000RPM.
boosthigh.zip
It was running fine on low boost after that for about 40min driving fairly hard then the turbo started to surge in second gear at about 3/4 throttle and make a fairly loud whine/turbo spool hiss and also a bit in 3rd but not as bad. No idea what caused it to do that but.
It also felt a bit sluggish considering it was on 10PSI, not sure if its overfuelling or not running enough timing?
Changing the plugs also seems to have fixed my temp issue, even after hiding it for a while it still only got to around 85 deg. Also the IAC seems to have settled down.
Cheers for the help and any ideas on the surging/ sluggishness would be great.
Thanks, shaun
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5622078
ok a few things,
mate,
I also having similar prob. just asking, how this related to cut speed limiter wire from ecu. coz i have notice one wire cut from my ecu [series 2]. not sure about the wire. thanks
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5625991
looks like its time for the bigger AFM, and proper tune with nistune (or normal remap, whatever). isnt it normally recommended u go Z32 AFM? (from memory thats what brother did with his - something bigger than RB25 AFM anyway). cause its going to be hard to work out any issues due to not having a proper tune and AFM for the bigger capacity, from any legitimate problems unrelated to that.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5628032
  • 1 month later...
Had a breakthrough today while checking my car again (coughing was getting way worse).
Pulled the AFM off for about the millionth time and decided to gut it to check the solder joints, a couple of the pins are dry jointed!
So ill touch these up when my housemate gets home with the soldering iron and see if this fixes it.
Moral of the story dont assume new parts are any good!
Its also going in next week for a vipec and tune so this is just a tempory fix to get me to work next week.
Cheers for everyones help and ill post back later with the outcome
shaun
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5679425
Brave person what puts a twin cam 3L RB in and runs a factory tune.
Works fine, I drove mine around for a few months untuned, it just maxes the afm rather quickly so you don't give it heaps of shit or rev it out. The load of the engine is calculated from the airflow, more flow, more load, different cells.
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5680574
shaun
Problem fixed no coughs or splutters at all!
https://www.sau.com.au/forums/topic/349390-consult-data/#findComment-5680906
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
