-0.36mv - where are you seeing that?
the hand controller ,reads straight from the ECU, which is coming from the TPS wire from the engine bay
from there, the PFC sends the TPS signal on another wire, to the ABS/A-LSD computer in the boot
so its that wire you need to check if its the same voltage (it sohuld be)
if TPS on the hand controller is always OK this means the sensor is OK and the wire from the sensor to the main ECU loom is OK
from there the PFC (and stock ecu) relay this signal to the ABS/A-LSD computers in the boot as the A-lSD needs to know how hard you pull the throttle cable
if that TPS signal *(the one relayed to the boot PC) dies, out of range or goes spazzo the A-LSD computer goes into fail safe mode and the light comes on and the A-LSD system gives up, ie no lock when wheel spin
  • Replies 42
been testing the voltage at the fc. with just the ignition on the volts to the fc are 0.568, it matches the hand controller voltage. Also the output to the attessa reads the same.
Once ive started the car the voltage at the fc slowly drops to -0.36mv, as if its lost the signal but the hand controller still states it has 0.5v. now im confused. is this a correct reading for tps output or is this why my
fault light is coming on?, but the hand controller says its all good. ahhhhhhhhhhhhhh
First check your battery and ground terminals are tight. Then:
Mesure your 5V rail vs sensor gnd with ignition on and then with the car running and see if it changes. Then measure your sensor GND to chassis gnd and see if there is any voltage difference between running and ignition on.
Also try disconnecting the TPS with the car running and also with ignition on to make sure it drops to zero so you can see that the hand controller isn't just giving you false information.
Has anybody ever checked the input impeadance of the TPS signal into the PFC and the attessa system matches??
i got the negative mv reading from the tps wire at the fc (#38) but only once the car is running. when the ignition is only on its fine at 0.568 v.
once i start the car the #38 wire starts at a low 100mv and slowly drops to the negative mv, can range up to -138mv then the fault light comes on. this does not happen all the time if the mv signal stays around -0.70 consistantly or under -0.7mv, the fault light does not come on but if it spikes lower it faults. but sometimes it stays at 100mv and no fault light.
could this be an earthing problem with the fc? engine or tps?
Rob82 which is the 5v rail i should test to gnd? ill test all the grounds and see if i get and changes or differances
Pulled out vin tps once running. Fault came up and tps signal went to 0.00 and black background on the sensor. Checked tps signal wire to tps earth read 0.5v. Then checked tps signal wire to chassis earth it came up with the negative mv reading. So checking figures to chassis earth gives me the negative reading. Still once the voltage reading spikes negative the fault comes on.
There is three pins at your tps 5V, signal and sensor GND. Check that the voltage between 5v pin and the sensor gnd stays @ 5V all the time - if it doesn't your have to start there - thats a big problem. You should always check sensor voltage with reference to sensor gnd not chassis gnd.
That being aid if you have negative dc voltages between signal and chassis earth you may have a rectifier issues within you alternator. you could try disconnecting the battery cable to the alternator with the engine running and see if the erratic tps goes away.
ah i see, yeah the tps remains the same 5v, but only when i test it with the tps earth. if i test the 5v with the chassis ground is where the problem lies. thats when i get the negative mv.
from what ive found 9correct me if im wrong, is that the signal for the handcontroller uses the tps earth giving it 5v. when i test the signal wire #56 which the fc use to translate the tps signal to the attesa it uses the chassis earth which is in mv. my erratic mv signal dropping to the negative trips the fualt.
SO
i put another earth from pin #60 (fc main gnd) to the chassis, where the fc bolts onto the chassis including the fc bracket. What this did is stop my negative mv reading and brought it up to 300mv around there but not in the negative. This in any way has not affected the 5v reading to the tps or hand controlled its simply having a better ground to the fc
so far i have not had the fault come on, YET!!!!
so far so good.
keeping the signal to the attesa in the posative mv range seems to have fxed it, but i havnt got my hopes up
thanks to all who have spent the time to post on this thread.
ill post back here if it fails again
Sorry to thread-jack. I'm having issues with my ATTESSA and TPS and reading through this I think I might be going down the right track now...
I am having my 4WD light com on and throw a TPS error code at me intermittently from 1-10 minutes of driving, usually at lower RPM. I have just swapped battery and alternator, the Power FC is reading 13.4V at idle now, and a tad under 12 with IGN OFF. My battery has been reloacted to the boot, using some heavy duty wiring.
I checked the voltages and resistance today on my TPS;
- I'm getting a good 5V constantly from +5V TPS Ground
- Signal -> TPS Ground or Engine (Plenum) it shows 0.5 Volts, as shows on the Power FC controller, and as does when tested from the ECCS module between 30 & 38pins.
- When I checked the same Signal wire to Car Chassis it is showing a higher 0.7V.
- I measured resistance from chassis to block and it reads 0 Ohms then Started the engine.
- The TPS now reads 0.53Volts Singal to TPS Ground, 0.66Volts Signal to Engine, 0.5mV or -0.5mV Signal to Chassis
Would I probably be correct in assuming I have an earth problem, especially as the TPS appears to test fine in almost every way the manual lists.
ADDITIONALLY
Running ATTESSA Fault Code 21 Tests showed me I should recieve approx 0.375V between 50 and 38, but I am getting 0.5V between the two, so the voltage is NOT stepping down to the ATTESSA output.
Thanks in advance to anyone who can help me with this, I'm going nuts
if TPS is 0.53v at idle this poses no issue for the ATTESSA system or the stock ecu
its only when its 0 that the ECU will throw on the engine check light or the ATTESSA system would crack the sads - much like the A-LSD system does
I doubt it would be 0V - most ECU's will recognise an upper and lower voltage input an it is rarely 0 or 5V more like 0.3V and 4.7V.
And yes it does sound like an earth issue - try tying your grounds together like the original poster and see what happens.
Thanks for the replies guys, I will re-earth the whole car tonight, might look at running another earth cable from block to chassis as well, weird I had put 100km on the engine before this started to happen, would have though it would have shown up form when the fresh engine went in right away.
hey it does sound like a simular issue i had.
if your getting a erratic negative voltage from the tps at the fc when earthing to chassis then run a temporary new earth from pin #60 (fc gnd) to the chassis (like where the fc bolts up) and then re test the signal from the tps to the fc ( pin #38)and see if it clears up the weak signal. your correct you should read over 300mv as the attesa uses that signal.
to answer your question im not sure on the resistance but it should be minimal.
Thanks, will give that a go tomorrow, I re-earthed the chassis to engine tonight, better in every way, except the same 4WD fault so will try the extra earth technique tomorrow night. I'm assuming you don't need a think wire, same guage as the ECU wiring should be fine?
No idea where that strap went. Thanks for all the help guys 4WD is running great now, run a wire from pin 60 to the wall and she's a treat. I appear to have some voltage issues still in regards to the TPS though, the 4WD is fine, but I'm having surging idle and poor accel below 3000 rpm. Is it safe to earth the singal ground wire on the ECU to the chassis also?
No Definately not. Sensor gnd is not chassis gnd. Have you tryed tying the sensor gnd of both ECU and 4WD together?
No I haven't the only ground touched so far was pin 60 and the engine-chassis earth where it meets the chassis, should I run a wire from pin 30 Sensor Ground (TPS, Engine temp) back to the ATTESSA computer and joining those two?
Weird question here; could the earthing of the ECU have changed the CAS sensor return to the ECCS and therefore change my timing?
If your chassis earthing the sensor gnd - then you will be loading the TPS, ECT, IAT, MAF and CAS. All sorts of bad things will be happening. You should tie the sensor ground of the ecu to the sensor gnd of the ATTESSA. You can also try re earthing all GND wires at ecu and attessa ecu.
yeah only earth the pin 60 to gnd (chassis)the tps and ecu use the sensor gnd. earthing the pin #60 should have no effect on the idle, tps or cas.
can always sus out the earth by taking it off again and see if the idle comes good and it goes back to before.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
