hey guys,
does anyone know what the bulb size is for the driving lights that often sit in the lower front bar on Dayz edition S2 stageas??? got the globe out and the light, but no markings on either to indicate the size and it isn't in the manual.
any help much appreciated.
cheers, mat
https://www.sau.com.au/forums/topic/349587-c34-dayz-driving-lights-bulb-size/
hey guys,
cheers, mat
are you refering to the bottom fog lights situated in the air dam.
I'm pretty sure that when i replaced my yellow globes with plain white globes they were H1 globes
I work at a holden dealer so i just grabbed some off the shelf.
if worse comes to worse, pull yours out and get super crrap auto to match them up
yeah mate, globes pull out of the connector. I still have to pull them apart again and remove the little metal covers.
It doesn't get too foggy down here on the coast, i'd rather have them for spotlights when i'm driving at night
Edited by Big Fella
great, thanks for that guys.
have relocated the lights to the outer vents on the front bar - now for a HID kit - once i get them ligned up properly it's going to be like daylight on the backroads!
a bit more research, and i'm fairly convinced they are HB3. i have downloaded a size schematic, so i'll measure it up at home.
you might be right in that the bulb is H1 - but if i want to go to a HID kit, i can't use the H1 bulb as the wiring to the ballast connects directly to the bulb base, and there would be nothing to hold it in place.
(the stock wiring clips into a 90 degree base (HB3), and the H1 globe slots into that). i'll post my findings.
whilst on subject of spot lights. i am getting some dayz foggies and relocating to the side vents aswell. this is to make way for the 32 gtr fmic. we get a fair bit of fog in the gully, where we live near the hills. i will crack em open to find out what globe they take for a part number ref. these are for a s1, so im betting they are slightly different, S2 look different, can someone confirm? i will try to find a pic.
smokey -did you have to make mounting brackets to fit them and line them up dead straight? no probs with the headlights, they have levellers.
i'd say they'd be the same between s1 and s2. they are a CIBIE brand light if that helps.
there are no markings on the globes or the actual housings - i looked.
and yep, i made brackets just using some 90 degree angle brackets, bolted into the underside of the reo. alignment will be a case of doing some bending of the brackets, loosening of the bolts and a bit of hammer time i'd say haha.
QUESTION: how do you switch them on! i can't get them to fire up, but i dont exactly know if what i'm doing is right. is the rocker switch to the right of the steering wheel the right one? because it has two positions and neither do anything, even with the lights on.
and beyond that, where is the fuse for them?
I turn mine on with the indicator stalk, same as the factory fog lights
then I have a rocker switch to the left of my steering column down near the handbrake release which switches between yellow foggies in the front bar and driving lights in the lower air dam.
Thanks Big Fella,
can you do me a favour - can you have a peek in there and see if there is a green lead wire running off the back of your yellow lights in the front bar down to the foggies in the air dam? based on that either/or switching function you just described, it might have something to do with why mine won't fire - because that wire is just hanging loose. i tested it with a multimeter and go nothing so i figured it was useless and cut it off.....
  • 3 weeks later...
Yes smokey the bottom lights have a wire running from the yellow lights/blinkers to the lower fog lights, both plugs come from the same loom so u may have cut urs off, oh and the globes are very easy to come by, got new ones from super cheap auto, think the globe type from memory was H1 12v 55w
Edited by Chris_Beli
ah feck.
so i'm figuring it must be some sort of relay trigger wire, or it's an earth so that when you hit the switch for the lower fogs, the orange fogs cut out.
any ideas how i'm going to work this one out????
  • 2 months later...
didnt end up wiring them up. i live in an apartment building so body corporate forbids working on cars in the garage.....so never managed to get round to it.
but your choices are - use the factory loom if present, and find out which wire is the trigger wire. i'm guessing that because you can only switch on either the front bar lights, or the driving lights using the rocker switch - one of them gets grounded and the other becomes open. so that wire between the two is probably a ground wire. so get the ground wire off the front bar lights, and splice it into the ground wire on your CIBIEs. if that doesnt work - try splicing the power wires together.
other option is to run a relay harness as per my other thread. get a HB3 specific one and it will be plug'n'play. that way you can have all lights on if needed. powahhh!
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
