Hey,I'm just wondering if anyone can help me or list all the bulbs that the 1998 Nissan Skyline R34 GT-T uses ?
Because it doesn't tells me in the owner's manual ?
Thanks
Edited by Jeremy1607
https://www.sau.com.au/forums/topic/349684-1998-nissan-skyline-r34/
Okay,thanks guys.I see that T10 wedge is the same as W5W ?
And if I want to install both the low and high beam HID kit,does that means I really have to uses 4 ballasts because there 4 different bulbs ?
Does it use W5W aswell ?
Thanks
Thanks
Yes you would have to use 4 ballasts, one for each globe, not sure about the W5W globes, T10's are easy enough to come by
You would need 4 ballasts for four bulbs.
It's generally not recommended to have HID on your highbeam (I believe it's because they take time to warm up, so flashing them doesn't work very well, and you typically turn highbeam on/off more, which is bad for the life of the bulb/ballast).
What's wrong with just a standard decent bulb in the highbeams? If they're HB3 connector highbeams as they are on mine, you could consider fitting HIR bulbs maybe? That would be a decent compromise in my opinion.
  • 4 weeks later...
One more things,a couple weeks ago I had Autosparks to install my HID kit.
When it's done,I noticed that all the wiring is completely different,now with rubber thingy,different cable and etc.
But I noticed the right headlight wire that connects to the end of the bulbs is loose.Sometimes the right headlight would turn on,but then if I go through speed bumps or bumpy roads,
the next time I turn it on,it wouldn't light sup,do you have any idea to fix it ?
Or should I just go back to the workshop who changed all my wiring and things ?
Because it wasn't like this before they changed it.
  • 2 months later...
For Skyline GTT if you want to do interior, number plates etc.
Front(X2) and rear inner sidelights(X4) - T10 501 capless or W5W(Same thing)
Number plate illumination(X1) - T10 501 capless or W5W
Side indicators - T10 501 capless or W5W
Interior map lights(X2) - 9mm bayonet(BA9S)
Middle interior light(X1) - 31mm festoon
Boot light - T10 501 capless or W5W
Rear outer sidelights and brake lights - T20 capless dual filament.
Rear indicators - T20 capless
Reversing lights - 912, T15 capless with 9mm base. Or you can use any bulb with T10 W5W base(IE 6/9 LED bulbs)
Courtesy of Skylineowners.com :thumbsup:
  • 5 months later...
:thanks:
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
