I'm not trig to be downer but do you need a 52mm radiator? The stock radiator is fine for decent power levels and some of the larger radiators keep the temps a bit low when street driven. I'd only consider a 52mm if your going to be racing
https://www.sau.com.au/forums/topic/349776-will-this-fit/#findComment-5617850
I spoke to PWR about a 52mm radiator and they suggested if it wasn't for track then they wouldn't recommend it on the street as you need to have enough road speed to get the air through it. I guess drift won't have the same sort of road speeds as track, so you may have the same issue. And on the GTR a 52mm needs to have the fan modified to fit, don't know about GTS.
https://www.sau.com.au/forums/topic/349776-will-this-fit/#findComment-5618934
yea the stock radiator really is far more capable than most people give it credit for. did you check the thermostat? have you pressure tested the cooling system? eliminate the head gasket? you need to do these things to first determine exactly what is causing the problem otherwise you will waste a lot of money replacing parts that have nothing wrong with them in the first place.
Edited by jonboy
https://www.sau.com.au/forums/topic/349776-will-this-fit/#findComment-5619226
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
