Hey guys today i changed my clutch everything went well until i went to put the box back it. It would slide in but the input shaft would not go into the spigot bush. I checked and the spigot bush does fit over the shaft. I aliened the clutch using a clutch tool (it was plastic and i think this may be my problem) tomorrow i am going to get an old input shaft off of an R33 and ill see if maybe it is not lined up correctly. Short of this does anyone else have any ideas on what it could be?
https://www.sau.com.au/forums/topic/349875-problems-putting-gearbox-back-in/
There a pain to juggle back into the right spot. Make sure your gearbox is in gear and try turning the output shaft in case the input shaft isn't lining up with the clutch. May need to slip the prop shaft in to turn it
89cal is on the money, just did this myself it was fun to say the least!!!!!!!!!!!!! it,s also easyer if you can put a block of wood on the edge of the sump at the front and gently lift the motor up at front tilting the motor down at the rear this will make life easyer to aligne. just be careful not to lift on the sump itself. and turning the input shaft will help heaps.
Unfortunatly I've had my gearbox out twice in two years lol I know how much of a pain it is. But as said above, gently liftin the front of the engine up helps as well. Do this on the front edge of the sump where it is strongest
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
