not everyone can afford to head to matsuri.
im sure being a ranga parent with a mortgage wouldnt help much.
ajd is a pretty orrite alternative, spend the day talking shit with like minded folk, check out some cool cars (im rather looking forward to checking out the 110), and if nothing else... its cheap parking at the bay on a weekend during summer.
^ pretty much sums it up haha
the money i would spend on fuel getting there/hookers/casino/strippers/food/asian hooker/accomodation etc
is being spent on new shit for the pig that i needed,
by all means, drive over yourself and have a ball
oh, wait .....
:P
:nyaanyaa:
  • Like 1
oh, wait .....
:P
:nyaanyaa:
you go burn cvnt...
just submitted my entry, might have to fit some coilovers before AJD so i can tuck some tyre under the gaurds and look respectable
:thumbsup: thats the way mate represent the wags
Edited by 4bidn1
few gay cars are in this year, so I've been told...
Does it make you feel better to know that I vote no on 20% of the cars :P
unfortunately if it was just me voting I think we would have 50 cars.
We have to give people a go, remember it's a show about the driver, not about the car. We deny certain cars as the drivers have a different mentality to the driving enthusiast.
So it's about hanging out with like minded people and checking out a majority of tastefully modified cars.
+ BBQ lunch + coffee van + churroz.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
