Hey Guys,
There is a cruise on to help out the guys in QLD affected by the floods.
Here is a quote from my mate who is organizing it.
Please join us in helping the poor souls in Queensland by attending our cruise on the 22nd of January! All cars and people welcome! Starting point for Southerners is the DEC at 9:30am for a 10am departure. Then meeting the Northerners at Campbell town @ 11:30am, then down the coast to Swansea for Lunch.
Drivers donation is $10 with a gold coin for every passenger.
Please tell all your friends and help us in raising some money to help our mates in Queensland.
Plus it'll be a pretty amazing drive too.
Edited by zoidbergmerc
https://www.sau.com.au/forums/topic/349992-cruise-for-queensland/
Regent Street Meats just donated heaps of snags and burgers so looks like a BBQ might be in order!
make sure you RSVP on the facebook page so I know how many people I need to cater for.
~240 Attending
~390 Maybe Attending
This thing has gone nuts recently..
By the way as far as I know I don't know anyone else going on this cruise, so if you see me hanging around my car come over and have a chat :)
150+?? last i checked :pirate:
~240 Attending
got a pic ? so i know :thanks:
I don't think I have any with my clothes on... lets just say I'm a bit like a cross between brad pitt crossed with jack black. That's a general invite to everyone btw, nothing worse than being in a crowd of hundreds of people and not knowing anyone, the best way to pick me out is there's a massive key mark across the front of my white series 1.5 r33, with a decent amount of paint chips on the front too, unfortunately my love of driving gravel roads is not the best for my car :(
For serious, I'm 23, about 6 foot, shortish brown/blonde hair. I like long walks on th... wrong site.
Jay
Jay
ROFL :teehee: of ur car i ment budeee
Oh damn... I was hoping for some sort of romantic connection or something :P oh well, a man can dream. I might send some pics of my peni... car.. a bit later on. (There's about being on a forum which automatically makes me take the piss, sorry mate :))
Really looking forward to this event, I think I've talked some mates into it but most are put off by the highway drive at first or simply have prior events.
Jay
Would really, really love to be able to do this but wont have my car back from having a new head fitted in time for it :( Sounds like it will be an awesome day and would've been a great oppurtunity to meet some of the other guys on the forum. Hope it all goes well for everyone that does make and there can be a good amount raised for the poor buggers in QLD. Good Luck!
Jay
pinch.gif oh so ur a funny little F@rker ay yer i got a mate who is going i went down 2day for a run was good stuff all cars
There's a heap of cars going with one person mate, if you can't find anyone/don't know anyone I'll have space somewhere in the car (front may be taken but as yet all 3 rear seats are free). It's all for a good cause and should be fun, the more people the better.
Drop me a PM if you want a lift :)
Jay
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
