I'm going to say it - Read the PDF. It is covered VERY clearly, and even gives you model numbers of the belt you require, exact amount of teeth (Pretty sure 150 is wrong too, I think its a couple more)
If you read the PDF and then come here because you don't understand even though its in the plainest of English, then please, put your tools down and back away. You should not be building the RB25\30.
the PDF only goes into detail about 152T belts which require the tensioner relocated. it mentions a different 150T belt but doesnt give much info. its been covered in this section before but the PDF is very out dated and has no info on the gates belt
150 is not wrong, theres more than 1 way of doing this
gerg_r31, not sure exactly what you mean but you need to use 2 tensioners rather than 1 tensioner and 1 idler to get the cam timing spot on, unless you have adjustable gears
Edited by JonnoHR31
it doesnt come too close together with the 150T gates belt and the only way they could ever touch is if something let go, which usually means destruction anyway. i'm running the gates belt with 2 tensioners in the standard location without any troubles, only think that didnt fit straight away was the lower timing cover which needed to be trimmed on the top intake corner to stop the belt running, but from memory you have to trim covers with the tensioner relocated anyway.
    • Maine Coone, did look at but to big and fluffy As for performance dogs, we had Mals at work, performance dogs are fun to watch, but, way to much work for this old rooster
    • Yep, it was only an option on the Q50 Hybrid.  Same in Japan as far as I know. And doesn't use a centre diff like the Suby's do, so not the same as the WRX.  But it also isn't a reactive AWD like other Nissan AWD vehicles are, eg. Murano/Xtrail/etc.
    • You should have got a Maine Coone then. Only thing is they're big. But so cool, and just like a dog. Or, just get yourself a high performance dog. That'll teach you for wanting Parkour indoors 😛
    • Are you thinking of Bens R32? I don't remember if his went through the bonnet itself, but it went through the chassis rail. Brad (RISKIN) bought it, and turned it into a track car. It's funny how anti people are of Jim Berry now. I remember when I pulled mine out (during an engine change) and inspected it and found it cracking badly. At that point in time so many people were even on SAU, were so pro Jim Berry, and that was after Bens GTR exploded his quite publically.
    • That's one of the reasons I got that breed, they look weird, the other reasons are they small, they are very vocal, and run around like they are on crack, I didn't want a breed that just sits around, these two are like kids on red cordial  My daughter has one, and it's a laugh riot, constantly doing Parkour around the house, sits on her shoulder, plays catch, and constantly runs around the house taking turns chasing the dog around, her Bermese though, just lays around with constant bitch face, and just looks on in utter disgust at the cat and dog playing together
