i just wanted to know roughly what a gtst nissan skyline r33 is worth ?
a friend of mine is selling one and i don't want to get ripped off any help would be great thanks
GREY 1993 r33 gts t skyline
it is registered with road worthy, don't thnk they have done anything to it so just standard possibly a full body kit / dvd/tv player it is in very good condition though insise and out and has done about 180000kms
thanks also it is an auto matic turbo
https://www.sau.com.au/forums/topic/350411-93-r33-skyline/
just like mine..except mines better :D
depends on condition really, if its mickey mouse with good paint and everything works maybe 10k-12k, if its a bit ratty maybe 6-7k..
Really depends on the condition and how much you like the car and your mate...Personally i wouldnt pay more than 10k
I paid a mate 15k for mine bout 4 years ago, its in pretty good nick with 130kms on it but I think I paid too much.
Then Old Mate spends it all on a wedding and gets divorced 6 months later ,silly bugger.. :no:
Edited by Arthur T3
https://www.sau.com.au/forums/topic/350411-93-r33-skyline/#findComment-5625933
Lol, fail!
I personally wouldn't pay more than 7k tops seeing as it's automatic.. i'm fairly sure automatic gtst's sell lowish due to low demand.
https://www.sau.com.au/forums/topic/350411-93-r33-skyline/#findComment-5626250
Hey mate. I wouldn't wantto bad mouth your friends car as I haven't seen or driven i
but 180000km for $8k seems pretty steep evemore so cause it's auto.
I paid 9000 for mine last year from a dealer I got them down from $11 mainly cause they weren't open weekends so noone even got a chance to see the car
and all it needed was new brake pads and the disks machined and it was manual with only 87000 kms on the odometer
so if I were you I'd go no higher than $7 and only if your sure that it's been regularly serviced
if it has it's probably a better option than one with less kms as skylines are realiable it's just that some owners aren't
as long as you keep up regular service they can survive well over 200000kms hope this helps
Also is it still on the original turbo? Even If it hasn't been thrashed it might be on the way out soon
https://www.sau.com.au/forums/topic/350411-93-r33-skyline/#findComment-5626634
Why don't you hold on for a manual? More driver satisfaction.
Auto + Turbo = More Fuel Consumption eh?
Easier later on, to sell a manual than an auto with this type of car.
Suggestion:- PM FloydWestwood and buy his. It's just popped up F/S I think, and it's well...... Need I say?
https://www.sau.com.au/forums/topic/350411-93-r33-skyline/#findComment-5626688
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
