maybe sinse the fact that Clutch is in Melbourne, as well as Miss_R34, they should meet up.
Clutch seems to like her, and from the post's, Miss_R34 seem to be the only one who likes clutch. cupid?
its cos she hasnt been brainwashed by teh evils of sau yet
everyone eventually hates clutch
lolz
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5653757
I would lol so hard if miss r34 rocks up to a meet one day and it isnt miss r34.. its mr sherrin with a f**k of big mullet and missing teeth...
no offence to you missy.. just sayin
Lol Mohsen - you never know hey ;p I'll make sure to come and say hello to you personally - then you tell me what you think ;p
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5654153
Lol cupid Aaron ;p
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5654174
Lol cupid Aaron ;p
either that or collect and select.
Lol syfon got told!!!!
Yeh come say hello....
If you really are a lady boy version of bogan sherin I'm locking myself in the car lol
so now you can choose from Syphon Clutch or Mohsen.
And if she turns out to be a he, I want to take a picture of the reaction hahahahha
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5654976
Gimp - you failed miserably with your signature.
better luck next time though. lol
Edited by AaronNM35
https://www.sau.com.au/forums/topic/350613-new-girl/page/9/#findComment-5655955
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
    • Hi Everyone I am from West Pennant Hills in NSW. Been too busy until recently to attend to my RB25DET Series 2 engine until recently. I am planning to stick it into the S15 shell at this stage, unless a nice SR20DET turns up... For now, i am going to try and get the RB25 running and working well then decide what gearbox to use. My preference is to retain the SR20DET  6 speed gearbox and tail shaft to retain as much and least modifications as i can avoid. I am an old guy and won't be doing any heavy drifting so i don't need a bullet proof gearbox Does anyone have experience with starting the RB on a stand? I got everything setup as much as I can with the info i can find... endless searching and videos on Youtube I would be great to get some pointers Cheers Songo
    • Hey all, Recently have had my s1 r33 gtr serviced and noticed my coolant reservoir was topped up to the max line. Took the car out for 1 yesterday and noticed today the reservoir is completely empty.  Any ideas? Radiator is full
