Just wondering about M35 ARX's Standard stereo equipment.
Do they all come with Bose speakers? Or are there cheaper factory options?
I know the sub in the spare wheel seems to be a pretty rare option but not sure about the speakers, head unit etc.
Reason, being is that I'm looking at one that is currently 'on the boat' from Japan so they don't have any stereo info yet. ... Comparing this to one that I have looked at that does have the Bose (The sound is great!)
Not really a huge deal to me but interested just the same.
Edit. OK, after some more searching, I found that there is also a Clarion deck for ARX, so I suppose they would have lesser quality speakers?
Do they still sound OK?
Edited by jidge
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/
i have the base system.. speakers are panasonic.. head unit is clarion. All m35 and V35 head units are clarion units.. even the ones with Bose imprinted on em. I had to get my sisters one fixed which is bose, and its a clarion, found out by googleing the serial.
I think they sound good for a stock system. but since I pulled the DVD thing out the screen doesnt work.. looking for a double din one without the screen. i wanna put my system in :)
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5632658
aaron,
shoot me a PM I can probably help.
one thing to note on teh ARX as well. the 6cd does tend to destroy itself AND if the unit dies it takes the A/C with it. bear that in mind.
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5636339
Cheers Chris.
I am pretty much set on an ARX so I guess i will have to cross that bridge when i come to it.
Are they difficult to repair/replace?
Can you just disconnect them when they fail to avoid it taking out the air con.. Or does that take out the whole head unit.
PS. Had another look/listen to the stereo in an ARX I was looking at and I could not see Bose written anywhere, so I guess it was the standard system. It sounded pretty good to me.
aaron,
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5637728
up to 2007 I could fix them. now parts are becoming scarce for them. when the unit dies IT WILL TAKE THE A/C with it. there is no getting around this without spending money on new panelwork and controls.
the dead unit syndrome I can fix the F0 and F3 errors will write the unit off. if it happens that you get a car like this have a spare $1k handy.
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5637737
along that topic, my 6 stack in my RX is dead, but AC is ok still, but just started to die from time to time, is it possible to save the AC now by disconnecting stacker? or does it need to be repaired?
really dont want to have to spend another 1k on it ATM
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5638206
if its stating to fail - pull it out and send it up to me. I'll repair it and send it back. once it fails you have NO control over the A/C at all. it will lock on whatever you last had it on OR 24 deg.
stacker is not the cause of the dead unit sydrome..
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5638265
  • 1 month later...
Another question along these lines....
If the stereo fails in an ARX, is it possible to just replace the double DIN with an aftermarket double DIN? Or even if it hasn't failed.
There would be some cutting of the dash etc. But if it was done properly would it be possible?
Cheers
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708515
it will look like shit if you cut it
get a proper double din. but AFAIK they are only available in black. however in the US the beige interior was popular so might have them in that light grey that the RX and ARX uses
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708536
OK. So no cutting, that probably would be shit.
But not sure exactly what yo mean about getting a proper double din??
Cheers
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708579
Yup it's all one unit. Had it out the other day. And the cassette cd and aircon are one. You can separate I think but hell of alot work. And pain to do.
Edited by whitestag
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708853
Just forget the CD aspect of the stereo and put in a Spec dock and use your Ipod or Iphone. Then you will have music / video's and navigation all from your iphone. If you have jailbroken your Iphone you can even output the display of your ipone to your monitor.
https://www.sau.com.au/forums/topic/350931-m35-arx-stereo/#findComment-5708913
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
