Espress Posted January 20, 2011 Share Posted January 20, 2011 Hey Guys just bought a stock (aftermarket Pod and Cat back) R33 95 with 144000kms on it. Its pretty clean but now when I idle it revs up and down and occasionally stalls. Other than Idle the car runs extremely smoothly and pulls fine. My house mate disconnected and reconnnected this hose (in orange circle) and it ran fine for about 5 mins before falling back to the old problem, any ideas on what the problem is? Thanks heaps for the help guys, really happy with the car except for this. Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/ Share on other sites More sharing options...
Miguelone Posted January 20, 2011 Share Posted January 20, 2011 Did you wash your engine bay with water? Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5634474 Share on other sites More sharing options...
Espress Posted January 20, 2011 Author Share Posted January 20, 2011 Nah mate, btw thats not my engine bay. Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5634476 Share on other sites More sharing options...
Miguelone Posted January 20, 2011 Share Posted January 20, 2011 Ahh ok, have you checked out your coilpacks and your afm? Maybe your fuel filter? Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5634491 Share on other sites More sharing options...
leer34 Posted January 20, 2011 Share Posted January 20, 2011 check the two vacuum lines leading to your AAC, split in the smaller of the two hoses was causing me the same problem you are having..sounds to me like your losing air pressure somewhere Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5634579 Share on other sites More sharing options...
mad082 Posted January 20, 2011 Share Posted January 20, 2011 also put that hose back on so that your bov works, otherwise you will find the car stalls everytime you stop at a set of lights. Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5635097 Share on other sites More sharing options...
ricsvtr Posted January 21, 2011 Share Posted January 21, 2011 does the idle change when u move the steering wheel? If so, try cleaning the AAC valve, there's a tutorial on these forums Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5636022 Share on other sites More sharing options...
Espress Posted January 22, 2011 Author Share Posted January 22, 2011 does the idle change when u move the steering wheel? If so, try cleaning the AAC valve, there's a tutorial on these forums Nah doesnt affect it when I move the steering wheel, also gave the aac valve a good clean with carby cleaner and it didn't fix it, perhaps the valve itself is stuffed? Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5637211 Share on other sites More sharing options...
lagperformance Posted April 24, 2011 Share Posted April 24, 2011 is the factory bov recirculating still if not that will be your problem because factory bov spring to weak and leaks pressure when run to atmo Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5776752 Share on other sites More sharing options...
gotRICE? Posted April 26, 2011 Share Posted April 26, 2011 is the factory bov recirculating still if not that will be your problem because factory bov spring to weak and leaks pressure when run to atmo The spring isnt all that weak.. it will handle 300rwkw. It is designed to leak at idle, so it leaks regardless of whether its plumbed back or not. Id say that it isnt though. And because its leaking that air its overfuelling. That, or the car is saying FUUU to all that silicon spray. haha. Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5779843 Share on other sites More sharing options...
LeCoq Posted July 5, 2011 Share Posted July 5, 2011 im having the same problem. Im pretty sure its the AFM problem or the turbo is blown Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5898637 Share on other sites More sharing options...
gotRICE? Posted July 5, 2011 Share Posted July 5, 2011 Those are two very different things there.. lol I suspect that a blown turbo wont cause an idle hunt. It hasnt introduced any sort of air leak, it just wont boost anymore/much. Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5898650 Share on other sites More sharing options...
LeCoq Posted July 6, 2011 Share Posted July 6, 2011 Its not different. AFM is connected to the hose that leads to the turbo. Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5899988 Share on other sites More sharing options...
skylinesandman Posted July 6, 2011 Share Posted July 6, 2011 regardless of weather it fixes prob or not change the fuels filter also clean the hot wire inside ya afm if its dirty it will make a huge difference also check the butterfly in the intake as it can get a carbon build up and not seat properly in the intake Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5900214 Share on other sites More sharing options...
skylinesandman Posted July 6, 2011 Share Posted July 6, 2011 Its not different. AFM is connected to the hose that leads to the turbo. not if its in ya intercooler pipe Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5900929 Share on other sites More sharing options...
LeCoq Posted July 7, 2011 Share Posted July 7, 2011 nah mines not connected to the intercooler pipe. I dont have front mount Link to comment https://www.sau.com.au/forums/topic/351135-new-r33-hunting-idle/#findComment-5901919 Share on other sites More sharing options...
