  • Replies 49
AWD Turbo Challenge - Round 4 Results
pdf-med.gifMulticlub Hillclimb 2 OVERALL RESULTS
pdf-med.gifAWD Turbo Challenge ROUND 4 RESULTS
Congratulations Andrew Bartlett (Open), Michael Willis (Modified) & Craig Van Diemen (Club) for winning their respective classes.
OPEN WINNER:
MODIFIED WINNER:
CLUB WINNER:
Willall have four GTRs out there racing in the Time Attack 3 on Monday for those that want to watch
Willall R35 GTR WR600 - Keir Wilson
Willall R35 GTR WR450 - 'Carbon King' Sebastian Lip
Willall RH9 R32 GTR - Kurt Wilson
FBRE/Willall R32 GTR - Our very own Blue32
Quite a lineup, thats over 2000awkw between the four of them or an average per car of over 500awkw..... :cheers:
Note: No Disney Dynos involved :domokun:
What's wrong? 4000 laminated confirmed corrected printed calibrated killa watts at the wheels in Disney Land not good enough for ya?? Cheapest perfomance upgrade I did was spend $60 on a DD dyno run.....
AWD Turbo Challenge - Round 5 Results
pdf-med.gifAutosport Time Attack Round 3 OFFICIAL RESULTS
pdf-med.gifAWD Turbo Challenge ROUND 5 RESULTS
Congratulations Sebastian Lip (Open), Dryden MacDonald (Modified) & Damien Hirst (Club) for winning their respective classes.
OPEN WINNER:
MODIFIED WINNER:
CLUB WINNER:
Edited by Catford
AWD Turbo Challenge - Round 7
Autosport Time Attack Round 4
3rd October 2011 (Monday Public Holiday)
Mallala Motor Sport Park
pdf-med.gifTime Attack Round 4 2011 ENTRY FORM - NOW AVAILABLE
pdf-med.gifTime Attack Round 4 2011 SUPP REGS - NOW AVAILABLE
AWD Turbo Challenge - Round 9
Legend of the Lakes Hillclimb
4th - 6th November 2011
Mount Gambier
pdf-med.gifLegend of the Lakes Hillclimb ENTRY FORM - NOW AVAILABLE!
pdf-med.gifLegend of the Lakes Hillclimb SUPP REGS - NOW AVAILABLE!
Edited by Catford
  • 3 weeks later...
Good one, you will have fun
I am surprised there arent more entries from here - Collingrove is one of those things like Coopers Beer and rancid old Pie Floaters that simply must be done at some stage if you are a South Aussie. Very rich in Motorsport heritage and tradition that place :)
  • 1 month later...
AWD Turbo Challenge - Round 6 Results
pdf-med.gifMulticlub Hillclimb 3 OVERALL RESULTS
pdf-med.gifAWD Turbo Challenge ROUND 6 RESULTS
Congratulations Martin Donnon (Open), Artur Niedzwiecki (Modified) & Craig Van Diemen (Club) for winning their respective classes.
OPEN WINNER:
MODIFIED WINNER:
CLUB WINNER:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
