  • Replies 128
Wondered what happened to you guys, one minute you in my rear mirror.........netx your not. Glad to hear you made it home ok.
thanks.. yeh was a real bummer coz i was enjoying the ride.. i didnt know until the gf said i can smell burning rubber is that the stagea? im like nope.. umm woops my tyres flat
anyone get any pics of the poosar?
Edited by ToddZ
that will do it everytime TODDDD
Wow......Funny that. I was reading an article in the Manly daily the other day bout that V8 super car driver Coulthard, he crashed his car doing 300kms+ due to a flat tyre.
did anyone get any pics of my 33 , i hope so
I hope so too. Andrew pokes through all the pics....
And for Humbla's sake too. Genelle pokes through all the pics...
Free bump to you both LOL
;) you know me too well terry lol
Was it the one with the stripes down the side? That was very tidy I thought
I have a pic of that 33 with the stripe down the side... but I wasn't feeling the vibes for photos on the cruise... :( need to look at more car mags and get an idea of what they do
so mad at myself for missing this thing, any chance it will be less than a yr before another cruise?
...not if you go through school zones, setting speed records :P
Hmmm... traditionally end of year event - perhaps, depending on if it's superceded by something akin to a Racing Legends Night at Trackside - in which case > Old Pac Hwy.
Macquarie Pass events pop up too as a cruise from time to time.
Why not join up as a Member for extra info, special deals/discounts?
The club itself is pushin to hold cruises once a month to every second month so that we at least have an event each month.
You should look into joining up, the benefits such as discounted entry to events, discounted insurance etc, pay off very quickly.
Feb's event will be posted by Wednesday.
na mine was the other one :)
i have usually been a paid up member by the time events come around, cant wait for march at wakey which for once might not get rained out...last two track days ended up bucketing down on me so no new PB's for ages, still stuck at 1.16.00 and im hoping for 1.14 ish which i hear is respectable for a relatively stock R33/boat.
dont worry i wont set any new speed records in school zones, that was a vaguely ACA baiting comment in my profile i had forgot about..if u want me to change it i dont mind at all.
Last ticket was in 07 and plan to keep it that way..fingers crossed.
look forward to monthly events, great idea and emails out to remind lazy sods like me would be much appreciated :P
loved the pics from putty rd thread and the thought of seeing all those cars in the flesh bombing down the highway..orgasmic.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
