I'm just after a bit of advice with suspension, tyres, guard work etc.
*Rims are 18x9 +30 all round, with 235/40 front and 265/35 rear.
*Suspension is Tein Super Street, 4kg all round.
*Rear guards have the lips rolled, fronts are not done (yet) and have only the upper guard liner remaining
I'm finding that I'm getting a bit of scrubbing on the front, whilst leaning through some corners and turning corners that are downhill/off camber. Basically i'm looking to have no wheel arch gap if possible with this setup, and not have heaps of scrubbing (i can put up with a bit during U turns and the like)
Obviously rolling the front guards is on my to do list - will this fix everything at a height of say 330mm tyre to guard with a 235/40 tyre? Do i need harder springs? I'm also looking to upgrade the swaybar, how much body roll will one of these eliminate?
As for the back, I'm assuming I will have a bit more room (haven't put the rear coilovers in yet). I'm also looking for a similar height. Can i still run the 265 tyre at this height with just rolled guards? I'm willing to go back down to 235 if need be.
Thanks guys :)
https://www.sau.com.au/forums/topic/351926-calling-stance-minded-individuals/
265 is a big tyre for a 9" rim you wont need it. rears will fit piss easy though fronts just roll and remove lining if need be could be cos suspension is so soft im on 8/6 and front rubs although its pretty low.
roll should fix all your problemo's :thumbsup:
Ok cheers guys, will get the fronts rolled and all guard liners removed. If it keeps happening i might upgrade the springs to 6kg or something.
I'll see how the rear goes, hopefully when it cambers in it shouldn't rub. Next tyres will be 235, the 265s were way too expensive
This is where the fronts are at now... is this low enough? Could I get away with lower?
Car is not a 'daily' as such but it is my only car, and does like to get driven reasonably hard now and then so not looking for epic lows
  • 3 weeks later...
BUMP
Just chasing some 6kg Tein springs to replace the 4kg fronts on my super streets, which i can source easily enough, however i need to know the exact dimensions etc. I had a look at my current springs just now and could only see CO40 IJC written on them, this doesn't match up with Tein's part numbers however :(
Does anyone have another part number for 4kg super street springs?
This is the site I will be using to order new ones http://www.tein.co.jp/e/price_list/standaridized_springs.html
just buy springs locally. King Springs or whatever. All you need is the measurements. Will most likely be 65mm ID, then all you need to know is the free length.
Kings work in lb-in though. 6kg = 335lb. Kings will have 325 or 350lb.
Kings Prosport Catalogue
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
