I've always wondered if something like this existed, and it does! (and no, this isn't a spam bot) :P
Anyone had experience with these before?
http://www.fumoto.com.au/info.htm
Basically it permanently replaces the drain plug on your oil sump, so then all that is required is opening/shutting the valve to drain your oil out.
I've read around and people claim them to be quite bullet proof, and there are "distinct" 2 movements you have to do in order to open the valve, so no rocks or debris could easily fly up and bump it open.
They also claim to be installed as OEM in Fords, Toyotas, Freightliners, Caterpillars, etc. and wernt really available to public consumers until recently.
Anyways, I've just ordered mine. They are $33 each + $8 postage. I got the F-103 model to fit the RB26 plug thread which is 12mm-1.25.
https://www.sau.com.au/forums/topic/352057-fumoto-oil-drain-valve/
  • 6 months later...
Just ordered one for my car then. I also read that you can get them with a nipple, instead of just a straight hole. So you can attach a small hose and syphon it into bottles, or around suspension components if your car is awkward (i.e. not a Nissan :P). Genius idea. They advise you to secure the lever with a zip tie or hose clamp should you have an off-road vehicle or are super-paranoid. But could you imagine someone that doesn't like you coming and sticking his arm under you car.... :S
Alas, I'm sold!
I just did my first oil change since putting the valve on. I have to say it's so easy to just jack your car up, slip a bucket underneath and open the valve up.
Dion. Great to hear. Hopefully more will pick on these. The valve leaver is spring loaded, so it will be pretty difficult just to tap open. When you receive yours you'll know what I mean.
I've had a fair few PM's about how big it is and how far it sticks out. I think there's alot of speculation around this and are worried about it getting 'knocked', so I decided to take a couple photos during my oil change.
It's only 1cm longer than the original sump plug. And as you can see, it's still higher up than a lot of other things underneath the liner!
Guessing answer is yes, but can anyone confirm that RB25 is same as RB26?
Yeah mate, all Nissan sump plug threads post 1990 are the same - 12mm x 1.25mm. If you order on their site you'll find the product code is F-103 from memory
Edit: I'll amend my statement. There are a few exceptions like Patrols, Sentras and Stanzas. And if you want the nipple-type valve, you suffix your code with an 'N'. So, F-103N.
Edited by fastjetjockey
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
