  • 3 weeks later...
  • Replies 109
Bit of an update
HKS kit not coming now, i decided against it at last minute due to couple reasons
1. It's WAY too easy to get carried away when building a car which is what i nearly did here, this car is a weekend drive car not a strip monster so going with these turbo's was way too much overkill and would of most likely turned car into a strip only vehicle which i definately don't want
2. This is probably the main reason actually, i'm venturing out on my own with new business which requires a SUBSTANTIAL outlay in anyones books so any extra i had laying around for this car has now been injected into new business account to get up and running
So where to from here?
Given time i will fit set of -5 turbo's, cams, intercooler and new ECU then that will be about it, after all i want to use this car and keep it streetable
I have also toyed with selling it and buying a 34 R later on
Time will tell
I hear you mate.
It is very easy to loose focus when building theses things. I know I have over indulged with mine :O
I'm glad you realized this before it was too late. I have the same moto as you re maintaining a street able car.
-5's are an excellent choice and there are many cars now that show how good they really (and how powerful they can be).
Good luck with the rest Brett.
Edited by Ants
  • 4 months later...
Bit of an update as it's been a while
Tried selling the car to buy an R34 GTR but no one wants to spend there money buying new cars at moment
So what does one do when presented with this scenario?
Keep modding of course :yes:
Thought i'd finally upgrade the brakes as this is pretty much the final piece that needed attending to underneath the car
So just bought these
Will tie in perfectly with overall theme of car with gold nur engine covers etc ;)
Some more parts awaiting arrival
Couldn't believe this HKS kit was still available
PLAZMAMAN 100mm Intercooler same as in Powertunes 900+ hp GTR
TOP SECRET Carbon Ornament
Fitted to N1 Cover
Got home yesterday and there were couple boxes waiting for me to unpack :woot:
First of all the new cooler, these things are HUGE
2ndly the carbon plate and -12 fittings arrived for the N1 covers
No sign of the HKS turbo kit yet though :angry:
Sent email through and they say it was sent around week ago through e-go but i never recieved even email from ego which they usually send and i notice he still has this system listed on ebay - if not seen by end of week then i have no option than to start proceedings to get money back
I felt like xmas had come early this afternoon when this arrived at front door :yes:
Once all unpacked it looked a little something like this
Yepp, 1 complete top mount HKS turbo kit capable of upto around 1000HP :w00t:
Not going to unwrap everything though as need to build motor before these are attached but did unwrap a couple of things to have a look at
I had to laugh whilst unpacking though, i was thinking how the hell does this all go together :rofl2:
That'll be job of engine builder me thinks :yes:
HAHA I would be thinking the same thing...
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
