I am looking to purchase a R33 GTS-t with in the next week and am wondering where is the best place to get all the mechanicals checked out? I have found the one i want but don't want any mechanical troubles out of it.
The car is in Brisbane on the northside. I do not expect the driver to take it too far away as i am not wanting to stuff him around. I just want his car. :rolleyes:
What are your reccommendations?
Cheers
https://www.sau.com.au/forums/topic/35237-mechanical-inspections/
Well i got my r32 checked out by Gavin Woods Autotek at labrador..
I was happy with the work he did, however he did tell me a problem that was not a problem, and charged me for a data inspection i did not recieve, however i havnt had a chance to speak to him about this..
it will cost you $60 for the inspection and another $60 if you want a data stream OR a compression test.
Take it to gavin, one you have put a deposit down .. (write up a contract stating you want the full depost refunded if it does not pass the mechanical inspection to your liking)
this is a legally binding contact and will last 3 months, therefore he can not let anyone look at it or sell it to anyone for 3 motnhs while he still have your money.
sure ita an hour south, but if he wants to sell you the car, he will be willing to do so
I'm not sure whether that is true mindflux. I know a deposit is *meant* to be binding, but I think the seller can refund the deposit at any time and not sell you the car if they decide. 3 Months I doubt they actually have to keep the car for that long. Otherwise I could go around town and put deposits on 50 GTR just *incase* in 6 months i had enough to buy one, and they couldn't sell it to anybody else. I dont think that is how it works.
Likewise I know plenty of buyers who pike on their deposits and don't take the car.. so its not binding in that way.
I just took it to RACQ, but because my R33 was an import I hads to take it to the main RACQ operations Centre at Eight Mile Plains.
They went through it with a fine tooth comb, and pointed every single little thing that was out of place even down to these cracks in the Mags, which were replaced before I bought it, but I would not have thought tolookat them.
Cost a bit though, $270 for the mech and electrical inspection plus 1 years membership with RACQ. Money well spent if you ask me!
predator - yeah im 99% sure im correct, i couldnt be bothered looking it up to tell you if im wrong.. but quite a few people have told that its a contract for 3 months..
and yes your correct the seller can refund your money whenever they feel like it, and im pretty cure the buyer has to accpet the refund otherwise it wouldnt stand up in court
but yeah i couldnt be botherd explaing :D
Thanks for the reply's
I am about to book it in with stateroads. They come round and do it all in the owners drve way. Cost - $179 but has full compression tests, previous damage and encumberance checks.
If all goes well the Skyline will be in my garage on tuesday night!
I hope so anyway.
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
