Hi all, the time has come to sell my R34 GT-T sedan, it is silver grey metallic, has tiptronic either on the console or steering wheel, original 17" alloys with good tyres, good trim, Climate control, front and side airbags, traction control, a couple of minor blemishes, and is ACT registered.
This is a great car to drive and is mostly ummolested apart from a pod filter.
Perfect for the family Skyline driver with young kids, since two doors are a pain with booster seats etc.
It is a 1998 model, first imported with 93000 kms, I am the second owner in Oz. It has some of the japanese service stickers on the drivers door opening, but since I dont read Japanese I cant tell you what they say.
For SAU members only I am offering it for sale for $8500 firm,(apologies to others asking $12K and upwards) I know this is the cheapest one available in this condition but I have too many toys (7 motorcycles, R32 GTR etc) and some have to go.
I also need a cheaper car for my daughter, auto, four cylinder, power steering and air conditioning, not turbocharged, not Korean and I may take it as part payment.
This will be done on a first in first served basis, the first person with the money owns it.
I will post photos as soon as possible.
I can be contacted by PM or call me (Tony) on 0421985762 at reasonable times of the day.
Edited by Tony Brown
Ohh!
My wife has a 2002 Holden Cruze, blue.
Auto, 1.5lt
120,oookm (have to check)
Very well looked after.
Extremly good on fuel (around 5 to 6 lt per 100km)
Aircon needs re-gas.
Is that the kind of thing you are looking for?
(after driving my Toyota V8 she keeps wanting more power.)
I've got a little green Mazda 323 Astina? Runs quite well on fuel, aircon needs to be regassed and has paint protector peeling from bonnet. Other then that it's not too bad, wouldn't say it's immaculate, but would come up nice with a little bit of attention and care. Also, it's manual. Beautiful looking car by the way. PM me if you're interested.
Ok, due to some truly stupendous "OFFERS" LOL! to swap or take as part payment for overpriced cars that are of no interest , I am no longer interested in part swaps, swaps (was never interested is swaps) or any other offers than just being able to buy the cheapest R34 GT-T in Australia for $8500, no offers, firm price, if you can find another one cheaper...........go buy it!
The only swap I am prepared to take is $8500 in Australian Dollars.
Sorry if I seem a little harsh on this but if you were privvy to some of these "OFFERS" you would understand where I am coming from.
Swap my Skateboard, ol skool fibreglass chicago long deck with new trucks and 3 new poly urethane wheels + a $30 vodafone text card (Unused!) PS. Will throw in my almost new Nokia 8210 too. :rofl:
Wake up clowns - this one is worth over $12k.
Cash up the $8500 or please keep quiet huh.
Edited by Sinista32
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
