Does anybody know the stock rotor specs for a ser 2 hr 33 gts 4stud???? Been having a lot of trouble finding disks to match for the front and rear. Can never find this model listed any where would it be the same as a gts25? Since they come in 4 studs? Any help would be great cheers
https://www.sau.com.au/forums/topic/352629-stock-brake-rotors-hr33/
sorry, can't find their specs on any site I know either.
www.dba.com.au let you search by specs, so measure
A rotor diameter
B rotor height (disc to top of hat)
C rotor thickness (add a mm or 2 probably)
D PCD of wheel - it will be 4 x the distance between two opposite studs. eg 4x113
E outer diameter of the centre hole on the hub
See what you can find that is close. PCD can be fixed (they can redrill the discs), and so can rotor diameter if necessary (machine it down to a smaller size)
actually.....ebcbrakes.com does have a listing for R33 GTS 2.0 but I am not certain...you should still check.
It has part# D822 / GD822 which is
4 bolt holes
280mm diameter
50 high
22-20mm thick
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
