i just purchased my first r32 gtr. when i picked it up friday the car, when i started it seem to have a miss, but i couldnt tell. it runs like it have a bigger cam. sounds very lumpy. it only does it at idle. does anyone know if there is problem??? when you increase power, typical gtr exhaust note but when cruisin it sounds like it isnt running on all 6 cylinders. i have checked the spark plugs, coils, injectors. i think there my be some sort of air leak. i sprayed some aerostart near the no2 and no3 injector and the car ran perfect for a second the miss was gone and then came back again. also i looked under the rear of the car and the diff has the typical v spec oil cooler fins on the backing plate. does this mean its a vspec??? how else can i tell? can someone help? the car has done 90klm. also with the gtr are they still speed limited to 190km? thats where mine stopped.
https://www.sau.com.au/forums/topic/35272-r32-gtr-v-spec/
As far as i know all standard R32 GTR's have a finned diff all V-spec and V-spec II have a flat diff cover so the opposite of the R33's. Best way to tell is the model code V-spec II have KBNR32BFS8 AA where a V-spec does not have the 8 on the end and normal GTR's do not have the S or the 8 on the end.
https://www.sau.com.au/forums/topic/35272-r32-gtr-v-spec/#findComment-711652
The miss is no2 inlet gasket has blown which requires removal of the plenum/throttle bodies and inlet manifold.
There are three sets of gasket there and best to replace them all.
Have fun, it's a bitch of a job...
V Spec usually means that it has 330mm rotors and brembo calipers.
Finned diff means nothing...
Cheers
Ken
https://www.sau.com.au/forums/topic/35272-r32-gtr-v-spec/#findComment-732257
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
