hey guys just a bit confused
went to go take out the boost restrictor our of my mates r33 gtr to find out the boost solenoid/valve is t there, instead the two hoses are connected to eachother.
is this why he isn't runing 14psi/1 bar ??
hits full boost around 7psi
if anyone can help me source one would be gratefull
cheers
tilla
https://www.sau.com.au/forums/topic/352801-r33-gtr-no-boost-solenoid/
If the 2 solenoid lines were simply capped off and not joined together what boost pressure would the r33 gtr get, and what would be controlling the upper boost level. Thanks
Edited by thatlbeme
No that's not correct. If the STD lines are blocked it will run low boost. The solenoid opens to add a small bleed/vac to the wastegate pressure line. Closing the lines just stops the extra 2psi. You will find the valve state is normally closed. When installing an aftermarket controller new lines and routing is required to control boost over the entire range, rather than just 2psi
it will run 0.9 to 1 bar with the restrictor removed and the standard boost solenoid fitted
well i have had it setup 2 different ways
the old setup:
at the very back corner of the plenum theres a vac line going into it, that was pulled off, extended and then connected to the "actuator" port on my boost solenoid
the nipple that his hose used to go to on the bottom of my plenum was my pressure source
the new setup
B4stll.jpg\
2 equal length vac hoses going to the actuators
T'd together at the profec boost solenoid
I drilled into the bottom of the twin turbo pipe, installed a nipple and got my boost source from there
i changed from old setup to the new setup because it wasnt holding boost very well and boost curve was falling over.. 1.2bar down to 1bar, even at 1bar it was quite shakey in terms of boost control, it wasnt solid at all.
Boost control was much better with the stock boost solenoid, it would come up to 1bar and hold it there like a rock, but the only problem with it was that i couldnt go over 1bar
My tune is booked in for monday, im hoping this new setup will hold boost alot better than last time.
Edited by snozzle
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
