looks like i might be pulling out of the Cruise.
My tune today got cancelled. :( earliest I can get a tune is Sunday, and its WAY too hard driving around getting 250km on a full tank.
f**k i always copp the bad end of the stick.
i'll give all the maps and stuff to someone whos oming along..
scotty maybe...will you be a passenger
dont know at this stage.. looks like i may drive up to marysville, and we have to leave from there for a tune..it kinda sucks but its bcoming an urgency that i need it done
Ok so The Age(<= clicky) Seems to be telling us that it will be 22 degree's with chance of rain.
Is everyone still up for it? I really cant be ass'd delaying it again.
rain makes your car look cleaner lol.
i'll be bringing maps, and drive up to marysville - but may have to leave from there..
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
