Hey all,
Well I got my injectors seated into my rail and I reused my old O rings. I did not fit them into the car yet though. After reading, alot of people are saying not to reuse the O rings.
Problem is I cant find them and apparently Nissan charge half a penis for them.
To confirm, are these the parts I need?
"O-RING HOU LWR" - 16618 - 53J00
"O-RING HOU UPR" - 16618 - 10V05
Ive still got the rubber seats and the spacer shit, I just need to small and big O rings.
I found a few shops on eBay selling sets for silvias(in 4's) for a pretty decent price(I recall 10.60 for the item + about 10 on post). Is that my best option?
These are the links, if anyone can confirm these are the parts I need ill hassle the seller to make me a kit of 6.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200389911810&viewitem=&sspagename=STRK%3AMEWAX%3AIT
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=230221468057&ssPageName=ADME:X:AAQ:MOTORS:1123
Also found some EFI shop in Melbourne which I contacted but not too sure if they got the parts I need. If anyone has dealt with them or what ever, please let me know.
http://efihardware.com
Cheers!
https://www.sau.com.au/forums/topic/352996-injector-seals-help-r33-gtst/
Yeah it's sad Nissan charge either 6 or 8 dollars a seal which is f*ken ridiculous you could try efi performance they do seals can't remember how much tho also places like auto barn sell generic injector seals you take your old ones down an they match them up I payed 2 dollars a seal from there
The o-rings are a special type that doesn't break down over time with fuel hitting it. That's the reason they would be expensive. I re-used my old ones on my nismo 555's purely because it was Christmas and I would be without a car for a few days without injectors. No leaks so far, but I have a front facing plenum so if they do leak it's not hard to take them out and fix them.
If your desperate you can check your current o-rings for defects and if they appear ok then they may (I'm not saying definitely) should be ok to re-use
What to look for. Make sure there are no cuts, pinch marks, tears etc etc anything really that makes you worry either don't use it or put up a photo.
The o-rings should be a bit soft. Fuel o-rings are a little harder then some o-rings but if you can squish it a bit it should be fine. If it's rock hard and doesn't stretch etc then it's no good.
That is if you want to re-use what you have. It's a pain to fix if it goes wrong and you have a standard manifold but lol. Id keep that in mind
In the case of rubber, when I was talking to my mechanic (nissan specialist), he said the difference between genuine Nissan rubber (cam seals in particular as I had him do my 100k service) and aftermarket rubber (Gates) is significant. The Nissan cam seals are nice and soft whereas the aftermarket cam seals are rock hard, I'm not saying which is better for that cam seal application (hard vs soft), just pointing out quality difference what is supposed to be the same part.
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
