Greeting guys,
Newbie here. My car's a 1993 R33 Gts25t with mods:
Blitz pod with CAI + heat shield, FMIC hks gt 600x300x100mm, cat converter removed with 3 inch exhaust, hks sqv bov.
My car's done 90k, serviced every 5k (I used 100% synthetic - Mobil1)
1. Will I get 200rwkw when I install emanage and Profec e-01 boost controller (and get it properly tuned!)?
2. How does 200rwkw translate to BHP??
Cheers guys, awesome bunch! :headspin:
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/
  • Replies 45
Hmmm...
I think the man you need to talk to is Ben Martin :D
200rwkW is possible on the stock turbo but it's a freak thing where a good engine + a whole bunch of cheap mods (ie, dumps, EBC, FMIC) may get you there.
I would bargain on a lot more mods to get 200 RELIABLY day in day out like a good turbo like the HKS 2530.
The ECU is reasonably irrelevant, it may get you a few kW but it comes into it's own with you get up into the 225+ class.
200rwkW means something like 250 crank kW so it's a fair lot.
Something like 268rwhp.
T.
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705332
Thanks, I just want my skyline to be capable of 200rwkw but I dont need that sort of power everyday (too much traffic here in KL :D ).
From what I read in the threads, fuel controller adds a fair bit of power (around 10-20rwkw) on its own, and should make some more with an EBC.
so 200rwkw is about 330-340 BHP. Quite happy with that! Hehe, until the next round of mods
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705397
200 is not a huge ask. I had it with just power fc, fmic, full exhaust (but be aware, a not all 3" exhausts are equal), pod with partition and CAI and boost. This was at 0.85 bar, which I ran all day every day without a problem. At 1 bar, I think you would be closer to 210 or so, which is also realistically obtainable with stock turbo.
It will be very worthwhile to upgrade your fuel pump too, as a bit of insurance against detonation. Your afm may be out of resolution here too. Not a major problem if you will be running only one boost pressure for top end, but it can offer gains by upgrading. If you plan on upgrading your AFM, it is worth doing it before you fit the e-manage, it will save you a few dollars in tuning costs.
But definately get your fuel pump upgraded before you start more serious tuning.
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705446
Guest INASNT
My brother got 198rwkw from his 33 with just:
FMIC
Full Exhaust
Bosch Fuel Pump
K&N Pod (no CAI or heat shield)
Boost set to 12psi
Final Tune
This was at Advanced in brisbane, with standard computer and standard turbo.  So it is possible with simple bolt on parts.
so what did they actually tune since u got a stock ecu???
Any place can bodge dyno figures to read whatever u want.
gobiz
if u get z32 afn u will need new management otherwise the car will run like crap
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705764
INASNT, he is fitting e-manage.
gobiz, the boost pressure isnt the problem, its the airflow, as the AFM measures how much air is being sucked in. I know sydneykid hasnt had a problem at 200kw with the stock AFM, but mine hit 5.1V (max) at around 4500rpm with only 189rwkw. I know I am not the only one this has happened to. As mentioned, it wont make a big difference if you are tuning to one boost pressure, but if you want to tune to 1 bar, and be able to turn the boost down, the ECU may not see the change in airflow, thus overfueling.
If you are after a GTR pump, can I suggest a post in the Wanted to buy section, or try contacting www.d1garage.com or www.japanesemotorsport.com.au as they get these in quite often.
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705774
THANKS Steve,
I'll try looking for the Z32 AFM round the wreckers here in KL. I'll try to get the fuel pump as well.
*Sigh* just thought I had enough money saved for the mods......now gotta save up more
That always seems to be the case with modding, last time i put the FMIC in, I had to get a whole new front bumper plus get it painted plus get new signal lights.
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705813
gobiz
sorry, I meant tune as, new plugs, check timing, air fuel ratio, compression test, etc.
yes true i have seen a few places bodge dyno figures but advanced in brisbane is a very respected and well known workshop. depending on the day and the dyno, figures can be different.
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705828
gobiz, AFAIK there is only one Z32 AFM, 80mm (same as RB25) but has an orange sticker on it. If you are getting it from a wrecker, try and get the plug too, as they are different from a RB25.
If you dont have the $$, its not a huge thing at this sort of power level. Just tune the car up with stock AFM at around 0.85 bar you should have no problems with reliability at that sort of boost, and can drive around all day every day at the same boost.
Alot more important you upgrade the fuel pump - think of it as insurance.
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705853
Steve, is the emange very similar to a unichip. they both maintain the standard ecu, and they are both interceptor. they both control fuel and ign.
what im gettin at is that when i get my car tuned for 1 bar on wednesday, if my afm is running out of resolution, will the car still go alrite considering im gettin it tuned at 1 set boost level.
thanks
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-705964
Maybe, hard to say until the final tune is done. Can you check the AFM voltage when you do the unichip?
It would be worth getting them to tune it and do a run at lower boost (without changing the tune) and see what happens to the AF ratios. If she starts running rich you may have your answer.
Have you done your fuel pump yet dean?
https://www.sau.com.au/forums/topic/35306-can-i-get-200rwkw/#findComment-706024
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
