When my GTR arrives here in October I'm going to go through with some fairly massive modifications :D
I'm seriously considering the HKS GT3037S turbo's to be the main part of this upgrade...
I haven't had a chance to talk this over with my mechanic yet, but some things I am interested in is what else would I need to change to be able to withstand the pressure these might turbo's put out...
I know the thing's that I don't need to change in my r32 gtr are the Fuel rail, Plenum, Throttle bodies, camshafts/gears, pistons and headgaskets...
If anyone can help me in listing some NECESSARY parts I would need to purchase to help accomodate these turbos, I would appreciate it.
https://www.sau.com.au/forums/topic/35317-hks-gt3037s-twin-turbo-upgrade/
  • Replies 64
You can run those turbos on a standard motor. At the bare minimum you would need to sort out the fuel delivery system and injection computer.
If you wanted to use that setup to any degree of efficiency, you need:
a) a Very Expensive Gearbox (VEG)
B) rods for the revs for the high powerband that operates in
c) a nice clutch to go with the VEG, normally a chev or hollinger spline depending which way you go
d) a massive fuel system. We're taking three pumps if you go the Bosche route, or one big Barry Grant or Aeromotive with a fuel cell.
e) massive injectors
f) massive intercooler
g) headwork, headwork and more headwork
h) suspension mods: from either a traction or a safety perspective
i) brakes to slow this sucker down
j) uber sticky tyres, like the $500 each Dunlop R's, Nittos, BFG Drags
k) 1.5 or 2 way diffs would be a benefit
l) probably going to snap a driveshaft or two by now, get some spares
Now you can probably run the setup to 900-1000hp, you're going to want to unleash it a bit. Realising that you can't do squat on public roads, you take it to a track. To be kicked off because you don't have any safety gear...
Edit: that doesn't take into account alot of "minor" things, like new plenum, type of injection computer, ignition system, ETC/atessa mods, roll cage, one piece seats, fuel lines, regulator, pipework, engine internals, etc. etc. etc.
As soon as you go to fix one problem you'll realise that there are alot of associated things that go with it. Before you know it, you've spent over $30 grand with the end no where near in sight....
Hi ParagOn, Dough Boy is pretty much correct. Last time I added up the support systems necessary to enable proper use of a pair of 3037's it came to $80K plus the cost of the GTR to start with. From memory Munro is using a pair of 2835's (one full size smaller) and he has spent probably twice that.
As for 3037's being the "main part", the gearbox to handle them will cost more than they do.
I know Mario won't mind, this is the GTR700 spec, you would need similar.....
http://www.exvitermini.com/r33specs.htm
Hope that answers your questions, if not ask away, but be specific on what area your are interested in.
a) Will need to change, looking at a second hand hollinger... $15K ?
B) No idea on price.
c) Triple plat Ogura clutch already purchased... I think this would be sufficent?
d) Will need to upgrade
e) Will need to upgrade
f) Trust SPL? $1500 ?
g) Will need to do
h) full tein height adjustables already purchased
i) Will need to upgrade
j) Nitto's would be my choice... 265 ?
k) already has 1.5 differentials and nismo lsd
l) how much is a driveshaft for an r32 ;)
Thanks Doughboy for taking me seriously and listing in detail, help appreciated.
In all seriousness I'm near the end of my R33 project. All up price is around 80K, and it just started with "maybe I should bolt on a bigger turbo..."
I think a better way of approaching any project would be to set out your goals first. What do you want the car for? What do you expect from it? What budget is the absolute max you want to spend on it?
Alot of expectations don't mix, or could be made to work but would require alot more money and time. If you don't plan for that at the beginning you are going to be wasting resources.
So if this is all starting from winning a cheap set of turbos off an online auction then your project is starting behind the 8ball already. For starters you need to check out the compressor maps and work your way backwards to the motor rebuild. I could go on but I think you get the pic.
g) Will need to do
a) Trust H patterns, Pfitzner gearsets are around the 10k mark. Hollinger, OS 6 seq. $18+
B) Argos/Carrillos/Crower = $2k Eagle rods are cheaper but they are poorer quality. I know people would swear by them but why skip on a project like this?
c) OS rate their steel pressure plate triples at 700ps. The alum plate triple at 1200ps? Holly or OS boxes require different spline, therefore new clutch. GForce use a chev spline, say hi to a custom flywheel and Tilton clutch pack. At least $3k either way you look at it for new parts.
d) Cells are sub $500. A complete BG or Aeromotive system with braid is around $4k. You can use the Bosche setups but you need to run more pumps to cope with it.
e) Injectors are an easy one. $1500.
f) 4 layer Trusts can be had for as low as $2k used. The cooler the flow, the more power. Don't skip on this - it's easy power which will prevent detonation too.
g) How much do you want to flow? Can cost from $1k for a simple cleanup, $7k for all the bells and whistles. You'll need springs and titanium retainers at a minimum with high lift cams, $2k+
h) depends on what you want the car for. Everyone at the competitive drag level runs HKS or custom setups. Suspension mods may be in order too to improve geometry and hookup.
i) Run carbons like Mario. Spend 10K to have brakes you need to drive for 10 hours to heat up.
j) the biggest you can fit under the car. Have to be aware about diameter and gear ratios though.
k) Already got, saved some money - go to casino and celebrate
l) People have snapped the HKS ones. Not sure about custom costs, but probably be prepared to keep some handy for replacements.
I've been saving for this thing for 5 years, I've literally worked my ass off and haven't spent a cent on anything unnessecary :D
When I'm commited to something though I always try to go with it... a 0-300 car would be magnificent, considering the max speed on a Stock R32 GT-R with a Mines ECU has a max speed of 243 km/h, Pushing to 300 would be fairly easy, but getting there quickly is why I have decided on the GT3037S, ala Veilside R32 GTR, they run these, do the 1/4 in 8 and 0-300 in 13's. Not that I am trying to beat them or anything :)
Very true. What I've posted is decisions I've made, based on my limited knowledge and that of people I've come into contact with. If I had spoken to SKid, Munro and others before spending 1 cent (re: setting out goals before lashing out cash) I would have saved half my money.
I mean seriously if you wanted to spend that much on this car (and it wont be a road based car) why would you bother finding such a nice example to start with? I would have searched around and bought a bunky 15 year old r32 GTR and saved the money upfront to spend down the track. Also seeing as this car will hardly be driven on the road and only on the track I still cant see the point of it all. Mate you must have more money than a bull can shit. Spare me some? :D
Hindsight is a wonderful thing. If I had the intention to extremely modify a car from the word go I would have bought a cheap car that needed repairs. Hence why i said "a better way of approaching any project would be to set out your goals first".
Next car should be good though, thinking of a '69 fastback mustang with twin T51R's :D
does anyone know if 32's can run out of revs and gearing before the big 300?, that may also be a problem. Carbon fibre driveshafts are around 11k also
One thing you'll definately want to concentrate on is the suspension setup. Think about it logically, your going to need something that will be very stable at 300+ if you intend to go there, otherwise someone will be scraping you off their new pile of scrap metal. The last thing you want at those speeds is to start getting unstable.
Take the willal racing GTR, there not even hitting that mark yet across the 1/4 and they've had seriously scarey moments in the last part of the track on street tyres. You will definately need some body mods to reduce drag and lift in order to help your stability. You may also need a well sorted out wing in order to provide you with the necessary down force in order to keep it all stable...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
