  • Replies 66
Hi Gizmo.
Good to hear, like I said we just need to confirm that SAU is "an official club" so just waiting for prank now. These prices should be "unbeatable" and all profits going to support the CLUB.
Skylines Australia NSW is "an official club". www.skylinesaustralia.com is an online forum. We use the forums as a meeting room. Check with Jamezilla or funkymonkey about the status of the Victorian club.
Aaaah! forgot to give an update.. sorry guys.
Here's where we are at,
I pretty much secured a deal where SAU would become a "licensed distributor" on all exedy products limited to skyline models. They needed some other details which I felt would be best handled by the senior/pensioner/war veteran :P SAU guys, so I have handed everything over to James "jamezilla" and hopefully he will keep you updated.
does the discount still apply for a holden v8/supra 5speed combo, if its IN a skyline?
Prolly not :P
I dont think so... however until everything is finalised, things may change and it could be possible. It's best to keep in touch with this thread or Jamezilla for updates
  • 4 weeks later...
Maybe Admaz, on the cruise tomoroow you could apply the suplex or pile driver manouver on James, get him and the gang off their bums to finalise the VIC thing. I seriously think at this stage that's all that is holding the deal up..[james can confirm]
Yes, it will include flywheels. As not to step on other distributors toes, they suggested to limit SAU to Skyline/Nissan models only & anything from heavy duty up.
..[Jamezilla can confirm]
Shouldn't be taking this long???? Also be on the look out.. once Jamez sorts out this VIC thing out, I have a contact at a tyre manufacturer lined up to supply SAU permitting. ps: no crappy make either :mad: [spelling] OH-FEED-EL-SHUN :rofl:
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
