about to purchase new tyres all round for my r33 gtst. its a street car that sees grip driving. currently has 235/40 18 all round. plenty of room for the same size up front but the rear is the issue. to make the 235s clear guards with enough room for daily use it has alot of camber (factory gear). -3 on both sides. ive bought adjustable camber arms to be fitted at the same time to try and remove some but it seems only .5 will be able to come out before wheel hits guard. soooooooo, am i better off running a 225 instead of a 235 so i can remove more camber, working on the assumption the exact same tyres that are on their now. the rear wheels at 18x 9.5 for interests sake. not massively happy about how quickly tyres went with that amount of camber.
basically, what would grip more (assuming same tyre and conditions)
235 with -2.5 camber OR 225 with -1 camber.
https://www.sau.com.au/forums/topic/353396-tyre-width-and-camber/
Legal or not doesn't bother me. Rear guards are already rolled and ever so slightly pumped. I think as I have no concrete answers I might just stick with the 235, as I think the 225 will look too thin
The concrete answer is to get a rim with the correct offset & one whose width matches the tyre. Then run a camber number closer to one degree than three.
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
