Hey guys,
Got another set of wheels for sale, taken off one of the cars I recently purchased.
They are quite rare in this size and cost a sh!tload brand new. Wheels are silver with polished lip.
Will post pics up tomorrow night but from memory 2 of the rims have slight gutter rash.
Tyres were quite worn will check tomorrow but I'm sure there was at least 50% tread left on them. Good for atleast a couple (if not more) track days.
They are 18x10 with a +20 offset, suitable for R33 and R34 GT-R's. May fit R32 GT-R's but will need some sort of guard mods (lipping) and some decent negative camber.
Located in Narre Warren North (VIC) but will ship interstate at buyer's expense.
PRICE: $3200 ono
Pics to come.....
Cheers,
Jack
OK, here are some pics.
Pics of each individual wheel...
And some of the tyres...
As the pics above show there are a few marks on 2 of the rims, and the tyres have a bit of life still left in them....
PM or reply if interested, price is negotiable...
Cheers,
Jack
+1
These will fit in 32 GTR, maybe narrower tyres though.
Best of luck in sale Jack, I miss these.
+1
Yeah I'd say maybe a 245 or 265 wide tyre might do the trick.
oh geez.. jack, why do you always sell awesome rims that wont fit my evo? :(
Buy a GT-R!!! :P
Still for sale......
^^ Nah, I bought a set of CR KAI 18x9.5 +20, had 245/40/18 all around, and it rubs badly. took it off after 8days and sold it for dirt cheap price lol.
Have you got coilovers in your evo? Bit of camber, shaving the rear bar and the bolts for the rear bar in the wheel arch and they fit, although a +20 i don't know if it would fit haha. Plenty of evo's running 18x 9.5 though. I'll be running 18 x 9 on mine
^^ yep, cusco zero 2R, -2ish camber, still not good.
didnt shave the rear bar and relocate the bolts though..
anyway sorry for hijacking your thread, Jack. wondering what's the next rims you'll put on for sale.. :)
Edited by gerz
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
