gday guys
got a problem recently my battery decided to go flat recently but for no known reason so i thought mines a couple of years old and ill replace it, worked for a couple of days but now wont last for more than 7-8 hours and wont start after being connected for that period of time,
anyone know what could be wrong? alternator?
cheers
Kyle
https://www.sau.com.au/forums/topic/353657-battery-dying/
could be the charge rate the alternator is supplying. something draining the battery when parked up. volt drop through bad connections or inadequate cabling. does it only fail to start after being parked up overnight or wont start after running? check charge rate with a multimeter if you have one.
https://www.sau.com.au/forums/topic/353657-battery-dying/#findComment-5667283
well something is draining the battery. if you have a multimeter you should be able to use the 10A scale. pull a battery lead off and connect one lead to batt terminal and the other to the cable. then you pull fuses until the current on the meter drops right down and you should have an idea from fuse description where the drain lies...could be anything from alarm system to shorted diode inside the alternator.
https://www.sau.com.au/forums/topic/353657-battery-dying/#findComment-5667535
Do an amps drain test - remove the negative terminal of the battery and connect a multi meter between it, then read out how many amps you get (should be around 0.05amps) Before you do this make sure all accessorys are off doors closed etc. If its excessive start pulling fuses to identify which circuit is draining. Id start off with any aftermarket electrical items first, as there usually the first to fail or cause problems. If thats ok, check your alternator charge rate. It should charge the battery to around the 14v mark.....
https://www.sau.com.au/forums/topic/353657-battery-dying/#findComment-5672004
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
